pcm.multi {
type route;
slave.pcm {
type multi;
hint.description "MULTI OUT";
slaves.a.pcm "output";
slaves.b.pcm "rate48000Hz";
slaves.a.channels 2;
slaves.b.channels 2;
bindings.0.slave a;
bindings.0.channel 0;
bindings.1.slave a;
bindings.1.channel 1;
bindings.2.slave b;
bindings.2.channel 0;
bindings.3.slave b;
bindings.3.channel 1;
ttable.0.0 1;
ttable.1.1 1;
ttable.0.2 1;
ttable.1.3 1;
pcm.!default {
type plug
slave.pcm "multi"
pcm.output {
type hw
card 0
pcm.rate48000Hz {
type rate
slave {
pcm writeFile # Direct to the plugin which will write to a file
format S16_LE
rate 48000
pcm.writeFile {
type file
slave.pcm null
file "/tmp/snapfifo" # can test with /tmp/testsound.wav
format "raw" #test with "wav"
}pcm.!default {
type plug
slave.pcm rate48000Hz
pcm.rate48000Hz {
type rate
slave {
format S16_LE
rate 48000
pcm.writeFile {
type file
slave.pcm null
format "raw"
