Downloading Songs using Subsonic Android App
Postby SubVT802 » Sun Apr 02, 2017 12:38 am
I see no place to download songs via the android app. My server is working perfectly and I have download ability enabled on user.
SubVT802
Re: Downloading Songs using Subsonic Android App
Postby acroyear » Sun Apr 02, 2017 11:32 am
The Android app downloads automatically to its internal cache (in order to buffer a few files ahead, in case you hit a network dead zone for a bit - useful when driving long distances), but not to a 'public' place on your SD card. This was (initially) because of a security restriction introduced in Android 4.0.
It also (I think) only can read from that same cache when you are off-line.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby FlyingPersian » Sun Apr 02, 2017 1:48 pm
You can try using dsub. It allows saving your songs offline (either temporarilly or permanently). Then you can also access the *.mp3 files on your SD (or internal) card)
FlyingPersian
