Random Error
Random Error
Postby texxasrulez » Sun Apr 02, 2017 1:59 pm
I get the following error intermittently. A simple refresh takes me to subsonic without error. The error is as follows:
Exception org.springframework.dao.DataAccessResourceFailureException
Message PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 38,479,912 milliseconds ago. The last packet sent successfully to the server was 38,479,913 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 38,479,912 milliseconds ago. The last packet sent successfully to the server was 38,479,913 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
Java version Oracle Corporation 1.8.0_121
Operating system Linux 3.16.0-4-amd64
Server jetty-6.1.x
Memory Used 46 of 89 MB
Stack trace org.springframework.dao.DataAccessResourceFailureException: PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 38,479,912 milliseconds ago. The last packet sent successfully to the server was 38,479,913 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 38,479,912 milliseconds ago. The last packet sent successfully to the server was 38,479,913 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:103)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:59)
at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:93)
at net.sourceforge.subsonic.service.SecurityService.loadUserByUsername(SecurityService.java:47)
at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.loadUserDetails(TokenBasedRememberMeServices.java:308)
at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.autoLogin(TokenBasedRememberMeServices.java:218)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:104)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 38,479,912 milliseconds ago. The last packet sent successfully to the server was 38,479,913 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
at sun.reflect.GeneratedConstructorAccessor156.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:989)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3743)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2506)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2677)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2549)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1861)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1962)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
... 47 more
Caused by: java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at sun.security.ssl.OutputRecord.writeBuffer(OutputRecord.java:431)
at sun.security.ssl.OutputRecord.write(OutputRecord.java:417)
at sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:876)
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:847)
at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3725)
I will be adding autoReconnect=true to db url to see if error persists ..
EDIT: Subsonic will not start with autoReconnect=true argument in db url ...
texxasrulez
