Error: java.lang.OutOfMemoryError: PermGen space
Postby kundan » Tue Apr 14, 2009 4:54 am
Hi
i am getting following error with web application deployed in tomcat 5.5.16
and IE 6 i have tried cleaning up the work folder and tomcat chache and it works fine for some time before again throwing the error
dwr.engine._remoteHandleCallback('3','0',"jfreechart-48022.jpeg");
also there is a java script error as DWREngine not defined
When i run same web application in tomcat 5.5.27
and FireFox 3.0 i dont get these error.
the application has 2 be deployed in IE so plz help as to what i should do
kundan
Postby horto » Tue Apr 21, 2009 3:24 pm
hi
try increasing the JVM heap size -- set to 256mb, or 512. That should be plenty. As per http://www.informix-zone.com/node/46
e.g. when starting tomcat:
export CATALINA_OPTS="-Xmx512m"
$CATALINA_HOME/bin/startup.sh
not sure why this is required in your case but i've seen other memory-hungry j2ee apps fail on tomcat with the same error.
note: i don't think subsonic is memory-hungry, but maybe it is if you have a huge library. shrug. good luck!
horto
Postby horto » Tue Apr 21, 2009 3:28 pm
i spoke too soon
check the subsonic war deployment requirements - it clearly states it requires a container that supports 2.4 servlets (as per http://subsonic.sourceforge.net/installation.php)
if you look at the tomcat homepage, you see that starting with 5.5.27 it supports that:
2.4/2.0 5.5.27
(as per http://tomcat.apache.org/
so that is probably why it's not working on an older version of tomcat.
peace out
-horto
horto
