Session timeout
Session timeout
Postby Misenus » Wed Apr 12, 2017 3:34 pm
I see that several other users have posted having issues with this, but I can't see that any solutions have been offered. I have Subsonic running on my home computer, but mostly I want to use it at work on my work computer/phone. The problem is, my session is timing out, and I can't even log back in because Subsonic can't connect to the server. I have to text my wife and ask her to sign back in on my home computer to keep streaming at work. And no, my home computer is not asleep.
Misenus
Re: Session timeout
Postby jeggosh » Thu Apr 13, 2017 8:10 pm
This is not a solution
sorry, but wanted to get that out of the way before you hopes got too high
I've been having the same issue. I can log into my machine at home via teamviewer though
If i have subsonic auto-configure the "router to allow incoming connections" under settings>network, though it bounces back.
even if it is trying to connect and can't as soon as I save that again it will bring it up automagically.
Again, not a solution but maybe someone smarter than I can figure it out
running 6.1 beta 2 on windows 10 through a verizon fios GT784WNV router.
worked flawlessly until a couple months ago
I recently completely flattened my machine to see if there was something wrong with it and it is still happening.
Hope this helps
jeggosh
Re: Session timeout
Postby Misenus » Fri Jan 26, 2018 2:25 pm
Any fix for this? I'm at work right now, and I can't connect because my session timed out. This defeats the entire purpose of Subsonic.
Misenus
Re: Session timeout
Postby G8DHE » Fri Jan 26, 2018 4:29 pm
Sounds more like a problem with your account on the home based machine than a Subsonic problem, why is your session timing out on the home machine, why not run Subsonic as a service rather than an application on the desktop.
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Users browsing this forum: No registered users and 160 guests
