Video streaming not working
Postby Akegata » Fri Apr 14, 2017 12:29 pm
I added some video folders to my subsonic setup today, I've been using it for music only for a long time.
Some videos play fine, but most of them don't play at all. A frame from the video shows, then it loads for a while and eventueall the video window just spits out a url, like such:
https://subsonic.example.com:4443/hls/h ... tRate=3000
What's causing this, and how can I fix it? Is there a limitation on the formats subsonic can handle?
Akegata
Re: Video streaming not working
Postby Exrace » Sat Apr 15, 2017 6:06 pm
You might need to modify the converter settings or your setup is missing support for a converter.
Your subsonic log should have details.
Post the snip showing the error and others might be able to help.
Exrace
Postby Akegata » Sat Apr 15, 2017 6:47 pm
The log doesn't tell me much.
When I have a symlink to ffmpeg in /var/subsonic/transcode I get this error:
[2017-04-15 20:40:54,789] INFO TranscodeInputStream - Starting transcoder: /var/subsonic/transcode/ffmpeg -r 1 -ss 60 -t 1 -i /<file>.mkv -s 1067x600 -v 0 -f mjpeg -
No errors are written to the log.
When I remove the symlink I get this error:
[2017-04-15 20:38:26,843] WARN FFmpegParser - Error when parsing metadata in <file>.mkv
java.io.IOException: Cannot run program "/var/subsonic/transcode/ffmpeg": error=2, No such file or directory
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
   at java.lang.Runtime.exec(Runtime.java:620)
   at java.lang.Runtime.exec(Runtime.java:485)
   at net.sourceforge.subsonic.service.metadata.FFmpegParser.getRawMetaData(FFmpegParser.java:69)
   at net.sourceforge.subsonic.service.metadata.MetaDataParser.getMetaData(MetaDataParser.java:47)
   at net.sourceforge.subsonic.service.VideoConversionService.getVideoMetaData(VideoConversionService.java:119)
   at net.sourceforge.subsonic.controller.VideoPlayerController.handleRequestInternal(VideoPlayerController.java:83)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
   at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.io.IOException: error=2, No such file or directory
   at java.lang.UNIXProcess.forkAndExec(Native Method)
   at java.lang.UNIXProcess.<init>(UNIXProcess.java:248)
   at java.lang.ProcessImpl.start(ProcessImpl.java:134)
   at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
   ... 60 more
Akegata
