Subsonic no longer scanning for new folders
Postby sabinson » Sat Apr 15, 2017 4:03 am
Hello.
This is probably not a new topic, but I have not found any information on to how to solve the following problem. (I have been looking on google for over an hour.) Subsonic is no longer adding new folders to the database. I receive a message that the media folders are being scanned, but there is no count taking place on the right side of the screen. Also, there are no albums showing up in the Random listing. I run subsonic on a MacBook Air OS is Mountain Lion.
Here is the piece of the log file, which will confirm the problems I am facing:
4/15/17 12:01:44 AM BRT] INFO MediaScannerService Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Apr 15 03:00:00 BRT 2017
[4/15/17 12:03:37 AM BRT] INFO MediaScannerService Starting to scan media library.
[4/15/17 12:03:37 AM BRT] ERROR MediaScannerService Failed to scan media library.
[4/15/17 12:03:37 AM BRT] INFO PlaylistService Starting playlist import.
[4/15/17 12:03:37 AM BRT] INFO PlaylistService Completed playlist import.
[4/15/17 12:11:26 AM BRT] INFO MediaScannerService Starting to scan media library.
[4/15/17 12:11:26 AM BRT] ERROR MediaScannerService Failed to scan media library.
[4/15/17 12:11:26 AM BRT] INFO PlaylistService Starting playlist import.
[4/15/17 12:11:26 AM BRT] INFO PlaylistService Completed playlist import.
[4/15/17 12:29:17 AM BRT] INFO MediaScannerService Starting to scan media library.
[4/15/17 12:29:17 AM BRT] ERROR MediaScannerService Failed to scan media library.
[4/15/17 12:29:17 AM BRT] INFO PlaylistService Starting playlist import.
Here is my license and version information:
License Subsonic Premium
Version 6.1.beta2 (build dc75a2) – March 20, 2017
Server jetty-6.1.x, java 1.8.0_92, HSQLDB, Mac OS X (119.5 MB / 135.0 MB)
Troubleshooting Steps: I installed the new Beta, which did not resolve the problem. When I attempted to refresh the index, I received the following error message, which, of course, I do not understand:
Message PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version Oracle Corporation 1.8.0_92
Operating system Mac OS X 10.8.2
Server jetty-6.1.x
Memory Used 109 of 135 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:68)
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:147)
at net.sourceforge.subsonic.service.MediaFileService.checkLastModified(MediaFileService.java:119)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:89)
at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:157)
at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
at net.sourceforge.subsonic.controller.ArtistsController.handleRequestInternal(ArtistsController.java:112)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
... 64 more
Please help.
Sincerely,
Eric
sabinson
Re: Subsonic no longer scanning for new folders
Postby alphawave7 » Sat Apr 15, 2017 4:36 am
Uh oh...S1000 error usually means a fubard database. Delete old db and restart...you will need to recreate users,etc.
Postby sabinson » Sat Apr 15, 2017 4:58 am
Thank you for your reply. (I had to look up fubard in Google. I thought it might be a technical term.) How does one delete the database?
Eric
sabinson
Postby sabinson » Sun Apr 16, 2017 1:10 am
Hello, again.
I deleted the folder settings and moved my library to a new folder, all to no avail. No app is able to contact subsonic. I receive an unknown error message. On attempting to read the folder, subsonic gives the following error message:
Error
Message PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
Server jetty-6.1.x
Memory Used 82 of 133 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]; nested exception is java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:165)
at net.sourceforge.subsonic.service.MediaFileService.getMediaFile(MediaFileService.java:102)
at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:45)
Caused by: java.sql.SQLException: java.io.IOException: S1000 Data file size limit is reached in statement [insert into media_file (id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version) values (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)]
... 63 more
Come on, help me out. How do I get subsonic working again?
Sincerely,
Eric
sabinson
Postby Kliikko » Mon Apr 24, 2017 10:11 pm
Subsonic can be finicky sometimes, I strongly recommend you just uninstall and reinstall
Kliikko
Postby rumremix » Wed Jul 26, 2017 6:20 am
Eric, I've encountered a similar issue to yours. Did you ever find a resolution?
I tried deleting the contents of my db folder, and then reinstalling subsonic 6.1. The scanning still aborts after just a moment.
rumremix
Postby sabinson » Wed Jul 26, 2017 8:14 am
Hello.
I deleted the vestiges of Subsonic and reinstalled the program, as advised by Kliikko. I used AppZapper for the delete as I no longer like doing stuff in Terminal. AppZapper was on my iMac ever since 2012 (along with Pacifist) when I successfully used it to go back to an earlier version of iTunes. The reinstallation was successful. I rebuilt the library and so far so good. I suspected that if I didn't get rid of all of the program/app that crashed, I would continue having problems.
A belated thanks to Kliikko. Without his or her suggestion I would have been stuck as it was not obvious to me that deleting and reinstalling was the way to go. As iTunes is no longer useful for streaming from my Music library, Subsonic has become very, very important! If you are still having problems, rumremix, it just might be that dragging the program to Trash before reinstalling doesn't really get rid of it. Hopefully there will be a FAQ some day as to what to do when Subsonic has a melt down.
sabinson
Postby rumremix » Thu Jul 27, 2017 8:12 am
Hi Eric,
Although I'm a Mac user, my subsonic is running on a windows machine, where all my media lives. So I AppZapper won't work. But subsonic does provide an uninstall utility baked into windows. I ran that and re-installed. And yes, the issue seems to be fixed. Media is getting fully scanned again. Was a hassle reconfiguring all my settings though. Worse is the loss of playlists that I've been creating for years. I backed up my old data files but merging old with new seems more complicated than I was hoping. Anyway, thanks for the suggestion. I wish there was a simpler fix but the full uninstall did solve my scanning issue.
Sean
rumremix
