Subsonic 6.1b2 keeps crashing
Postby tenuhseegeek » Mon Apr 17, 2017 12:07 pm
Running on headless ubuntu server 16.10
Subsonic 6.1b2
Thought at first this was due to me migrating to MySQL but this happens when I switched it back to internal database as well. I see the ability to add "autoReconnect=true" in args, but not sure formatting in my string.
SUBSONIC_ARGS="--https-port=4443 --max-memory=150 --db=JDBC:mysql://localhost:3306/subsonic?user=MYUSER&password=MYPASSWORD"
Any help would be appreciated.
Crash output...
Exception org.springframework.dao.DataAccessResourceFailureException
Message PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 144,881,851 milliseconds ago. The last packet sent successfully to the server was 144,881,852 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 144,881,851 milliseconds ago. The last packet sent successfully to the server was 144,881,852 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
Java version Oracle Corporation 1.8.0_121
Operating system Linux 4.4.0-72-generic
Server jetty-6.1.x
Memory Used 49 of 118 MB
Stack trace org.springframework.dao.DataAccessResourceFailureException: PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 144,881,851 milliseconds ago. The last packet sent successfully to the server was 144,881,852 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 144,881,851 milliseconds ago. The last packet sent successfully to the server was 144,881,852 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:103)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:59)
at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:93)
at net.sourceforge.subsonic.controller.MultiController.login(MultiController.java:67)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:135)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 144,881,851 milliseconds ago. The last packet sent successfully to the server was 144,881,852 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:989)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3743)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2506)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2677)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2549)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1861)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1962)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
... 69 more
Caused by: java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)
at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3725)
... 78 more
tenuhseegeek
Re: Subsonic 6.1b2 keeps crashing
Postby n0rdik » Thu Mar 15, 2018 8:04 am
+1. For me, occurs with Subsonic 6.1.3 and mariadb 10.2. autoReconnect=true doesn't solves the problem. It might be a Subsonic bad mysql connection handling.
n0rdik
Users browsing this forum: No registered users and 66 guests
