songs not found for certain artist
Postby dpurcell » Wed Jun 07, 2017 12:31 am
Hi, I've been using Subsonic for several years now and today is the first time I've encountered a problem. Going through the browser, a particular artist (Stewart Copeland) displays along with the names of the two records I own, but no songs are listed for the two albums. My setup is that all of my music is in one folder with subfolders for artist and album, and there is nothing unusual in the directories that contain the two folders.
I removed the library and added it again, and also cleaned up the database -- neither of these helped. There are no errors in the log. This makes me think that there are likely other artists missing as well, though this is the only one I've found.
Any help? Thanks!
dpurcell
Re: songs not found for certain artist
Postby blueturtles » Wed Jun 07, 2017 3:58 am
You've done everything I would do. I'm sorry I can't help any further, but as a big fan of Stewart Copeland, I hope someone can help you figure this out so can listen to Mr Copeland again.
Sent from my SM-G920V using Tapatalk
blueturtles
Postby dpurcell » Thu Jun 08, 2017 1:22 pm
Thanks, blueturtles!
dpurcell
Postby Exrace » Sat Jun 10, 2017 7:36 pm
Try moving the folder and scan again.
You should see something in logs if it fails on the rescan.
Double check permissions.
Exrace
Postby dpurcell » Sun Jun 18, 2017 4:20 pm
If anyone has a similar problem, I solved it by following the directions here -- backing up the script file, deleting the db, restoring the script file, and rescanning:
https://wiki.cementhorizon.com/display/ ... c+database
Cheers!
dpurcell
