ERROR Using MySQL
ERROR Using MySQL
Postby texxasrulez » Wed Jun 14, 2017 1:05 am
License Subsonic Premium
Version 6.1.1 (build fc853b) – May 31, 2017
Server jetty-6.1.x, java 1.8.0_131, MySQL 5.7.18, Linux (77.5 MB / 143.5 MB)
Every time I visit my subsonic via the web interface I get a white page with the following error:
Exception   org.springframework.dao.DataAccessResourceFailureException
Message   PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 53,470,429 milliseconds ago. The last packet sent successfully to the server was 53,470,442 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 53,470,429 milliseconds ago. The last packet sent successfully to the server was 53,470,442 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
Java version   Oracle Corporation 1.8.0_131
Operating system   Linux 3.16.0-4-amd64
Server   jetty-6.1.x
Memory   Used 55 of 143 MB
Stack trace   org.springframework.dao.DataAccessResourceFailureException: PreparedStatementCallback; SQL [select username, password, email, ldap_authenticated, bytes_streamed, bytes_downloaded, bytes_uploaded from user where username=?]; The last packet successfully received from the server was 53,470,429 milliseconds ago.  The last packet sent successfully to the server was 53,470,442 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.; nested exception is com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 53,470,429 milliseconds ago.  The last packet sent successfully to the server was 53,470,442 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
   at org.springframework.jdbc.support.SQLStateSQLExceptionTranslator.doTranslate(SQLStateSQLExceptionTranslator.java:103)
   at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
   at net.sourceforge.subsonic.dao.UserDao.getUserByName(UserDao.java:59)
   at net.sourceforge.subsonic.service.SecurityService.getUserByName(SecurityService.java:93)
   at net.sourceforge.subsonic.service.SecurityService.loadUserByUsername(SecurityService.java:47)
   at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.loadUserDetails(TokenBasedRememberMeServices.java:308)
   at org.acegisecurity.ui.rememberme.TokenBasedRememberMeServices.autoLogin(TokenBasedRememberMeServices.java:218)
   at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:104)
   at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
   at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: The last packet successfully received from the server was 53,470,429 milliseconds ago.  The last packet sent successfully to the server was 53,470,442 milliseconds ago. is longer than the server configured value of 'wait_timeout'. You should consider either expiring and/or testing connection validity before use in your application, increasing the server configured values for client timeouts, or using the Connector/J connection property 'autoReconnect=true' to avoid this problem.
   at sun.reflect.GeneratedConstructorAccessor246.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
   at com.mysql.jdbc.Util.handleNewInstance(Util.java:425)
   at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:989)
   at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3743)
   at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2506)
   at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2677)
   at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2549)
   at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:1861)
   at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:1962)
   at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
   ... 47 more
Caused by: java.net.SocketException: Broken pipe (Write failed)
   at java.net.SocketOutputStream.socketWrite0(Native Method)
   at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
   at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
   at sun.security.ssl.OutputRecord.writeBuffer(OutputRecord.java:431)
   at sun.security.ssl.OutputRecord.write(OutputRecord.java:417)
   at sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:876)
   at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:847)
   at sun.security.ssl.AppOutputStream.write(AppOutputStream.java:123)
   at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:82)
   at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:140)
   at com.mysql.jdbc.MysqlIO.send(MysqlIO.java:3725)
A simple refresh (F5) will clear error and I can use the web interface.
Memory is set for 250
Last 10 lines of subsonic.log
        at net.sourceforge.subsonic.service.SettingsService.validateLicense(SettingsService.java:1408)
        at net.sourceforge.subsonic.service.SettingsService.access$000(SettingsService.java:52)
        at net.sourceforge.subsonic.service.SettingsService$1.run(SettingsService.java:1431)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:748)
I have tried changing my database settings, wait_timeout' and others, but no change.
Any insight would be great. Thank you ... 8)
texxasrulez
