Custom URL not working after upgrade
Postby msujdog » Fri Jun 16, 2017 8:35 pm
My yourname.subsonic.org address is no longer working after upgrading to 6.1 It used to work fine. Nothing in my router settings have changed. I'm able to manually get to my server just fine using my IP address, but I'd rather have the static name as my IP changes occasionally from my ISP. Ports 80 and 4040 are wide open as best as I can tell.
Here's the error I get:
Failed to test web address. Connect to subsonic.org:80 [subsonic.org/127.0.0.1] failed: Connection refused: connect (HttpHostConnectException)
msujdog
Re: Custom URL not working after upgrade
Postby bucc5062 » Fri Jul 28, 2017 12:03 pm
With 74 views I'd hope someone might step in. I upgraded to 6.1.1 then got premium. After setting up the custom url I find I cannot access subsonic via custom though the raw IP works. Port forwarding is enabled for the standard port on my router so.....did something change that stops being able to use the custom name?
bucc5062
Users browsing this forum: No registered users and 87 guests
