Changing from WAR to Stand-alone without loosing settings
Postby samotano » Sun Apr 19, 2009 1:05 am
I have had Subsonic for a few years when the only version available was WAR with Tomcat running. For ease of maintenance I would like to switch to te Win Stand-alone version and I was wondering what I have to do NOT to loose my settings. Some questions:
-Where are all the setings saved?
-Can I simply back them up in case something goes wrong?
-I am planning to remove Tomcat, do I wait until the stand-alone version is installed?
Thank you!
samotano
Postby sindre_mehus » Sun Apr 19, 2009 8:08 am
All settings are kept externally in c:/subsonic, and are not touched when uninstalling.
Hence, changing between war and standalone version should work just fine.
Postby samotano » Sun Apr 19, 2009 2:54 pm
Thank you!
samotano
Users browsing this forum: No registered users and 44 guests
