SubSonic broken on upgrade to Ubuntu 17.04/Java 8/9
Postby zcab911 » Mon Jul 03, 2017 5:07 pm
Recently upgraded to Ubuntu 17.04, which only provides access to Java 8 and Java 9 (Java 7 has been deprecated). I get the Error 503 message now. I have used Subsonic for a Decade, and prefer to let it run on a lower power Linux box. Here's what I have tried thus far:
Forcing install of Java 7 (unsuccessful)
Removing completely and reinstalling subsonic. No longer see any var/db subdir at all. Directory contains only "jetty", "transcode" and log filr.
Please help!
In the meantime I have reinstalled Subsonic to my Windoze machine (8-core energy hog), leaving my linux box hobbled. Hate to lose access to my music... particularly on my rides...
zcab911
Re: SubSonic broken on upgrade to Ubuntu 17.04/Java 8/9
Postby zcab911 » Mon Jul 03, 2017 5:57 pm
Tried standalone install... same result. Here is the logfile after running script:
[0.008s][info][gc] Using G1
72 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@2133c8f8: display name [org.springframework.context.support.ClassPathXmlApplicationContext@2133c8f8]; startup date [Mon Jul 03 10:52:55 PDT 2017]; root of context hierarchy
124 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
[0.439s][info][gc] GC(0) Pause Young (G1 Evacuation Pause) 9M->3M(62M) 7.987ms
[0.710s][info][gc] GC(1) Pause Young (G1 Evacuation Pause) 8M->5M(62M) 7.215ms
546 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@2133c8f8]: org.springframework.beans.factory.support.DefaultListableBeanFactory@24269709
556 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@24269709: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
575 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /var/subsonic/standalone/subsonic.war
Extracting webapp to /var/subsonic/jetty/2a8e8d
606 [main] INFO org.mortbay.log - jetty-6.1.x
643 [main] INFO org.mortbay.log - Extract jar:file:/var/subsonic/standalone/subsonic.war!/ to /var/subsonic/jetty/2a8e8d/webapp
[1.072s][info][gc] GC(2) Pause Young (G1 Evacuation Pause) 16M->6M(62M) 6.526ms
[1.289s][info][gc] GC(3) Pause Young (G1 Evacuation Pause) 22M->5M(62M) 5.257ms
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/var/subsonic/standalone/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/2a8e8d/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
[2.573s][info][gc] GC(4) Pause Young (G1 Evacuation Pause) 42M->10M(62M) 14.710ms
7423 [main] INFO / - Initializing Spring root WebApplicationContext
7423 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
7446 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@4eb386df: display name [Root WebApplicationContext]; startup date [Mon Jul 03 10:53:03 PDT 2017]; root of context hierarchy
7483 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
7629 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
7703 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
7743 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
7789 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
7817 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
7885 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]; nested exception is org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:420)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:342)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:310)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:92)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:123)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:422)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:352)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:473)
at java.base/java.security.AccessController.doPrivileged(Native Method)
Caused by: org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:138)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1292)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1287)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:135)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:92)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:507)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:398)
... 48 more
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
at org.apache.cxf.jaxws.spring.NamespaceHandler.init(NamespaceHandler.java:34)
at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:129)
... 54 more
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:466)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
... 56 more
7905 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@7bb6ab3a{/,jar:file:/var/subsonic/standalone/subsonic.war!/}
... 48 more
... 54 more
... 56 more
7911 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]; nested exception is org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException:
7937 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
8005 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
15471 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
[15.926s][info][gc] GC(5) Pause Young (G1 Evacuation Pause) 37M->12M(62M) 15.948ms
15748 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[192.168.0.5:9412](local),objID:[0:0:0, 0]]]]
root@gazoo:/var/subsonic#
zcab911
Postby zcab911 » Mon Jul 03, 2017 7:28 pm
Further information...
I installed 6.1.1 on a Widoze desktop that previously had subsonic installed (but I removed after migrating to Linux), and I had the same error 503. Then I installed on a laptop that had never seen subsonic server, and it was successful, though this was only a test. Could it be that in both cases, there is a Jetty bug left over from 5.3 or 6.0? Pretty lost here.
I may try installing on a RPi3, though I have had problems in the past when this was attempted (song never played through). I will still continue hacking at this problem until resolved. I love Subsonic, but am so bummed its broken.
zcab911
