Web player doesn't play past the 1st track after update
Postby benjmiller » Tue Jul 04, 2017 3:18 pm
Problem Description: updating past 6.0 (including 6.1 betas and the official 6.1.1 release) breaks web player playback functionality
Troubleshooting Steps: Downgrading back to 6.0 fixed the web player for me
Playback Application and version: (The end application that you are using to stream from Subsonic)
Subsonic Version: 6.0 (build a7857c) – April 30, 2016
Server Version: 6.0 (build a7857c) – April 30, 2016
Hardware Platform: Mac osSierra
Java Memory Limit: 150
Problem Filename: Doesn't seem like a file issue
Output from ffmpeg -i: ffmpeg command not found
Whenever I upgrade to anything past 6.0 including the betas and the new official 6.1.1 release the Subsonic web player breaks. After I update Subsonic the web player only plays the first track of any album I play. It just spins and spins when the next song comes up. I was hoping it was only going to just be an issue with the betas but I'm afraid not.Downgrading down to 6.0 fixes my issue. Any assistance would be appreciated.
Ben Miller
benjmiller
Re: Web player doesn't play past the 1st track after update
Postby triplesixes » Fri Jul 07, 2017 1:16 pm
Same problem, but using Server 2012. Tried different transcodes and the only thing that seems to work is stream FLAC without transcoding to MP3.
triplesixes
Postby Deviant0ne » Fri Jul 07, 2017 9:39 pm
Many of us are experiencing the same issue across multiple platforms (FreeBSD here), see the following threads:
viewtopic.php?f=2&t=17370
viewtopic.php?f=2&t=17466
As suggested, the only work-around I've found so far is to play FLAC files directly i.e. no transcoding. This issue only seems to affect the web player, apps seem to work fine.
Deviant0ne
Postby benjmiller » Sun Jul 09, 2017 4:37 am
This has been reported as a bug: https://sourceforge.net/p/subsonic/bugs/175/
benjmiller
Postby sunspot42 » Fri Jul 14, 2017 7:32 pm
This is happening to me too, but oddly it doesn't always hang. Sometimes it'll move on to the next track, sometimes it doesn't. Probably has to do with which cuts require transcoding and which don't.
Since I have unlimited bandwidth and 130 megabits upload speeds at home now after dumping Comcraps, I'm going to turn off transcoding for the web client...
sunspot42
Postby Deviant0ne » Tue Jul 18, 2017 1:11 am
This has apparently been an issue for a number of years, searching "Subsonic content-length" returns a number of results, dating back a few years. At this point, I am not holding out hope that this will be resolved any time soon. Also, the latest beta of Madsonic suffers from the same issue.
Deviant0ne
Postby benjmiller » Fri Aug 04, 2017 2:41 am
It is interesting that this is cross platform. Can we please get a dev to comment?
benjmiller
Postby btrbver2 » Fri Aug 11, 2017 10:29 pm
Wanted to bump this thread as another user with the same issue.
License Subsonic Premium
Version 6.1.1 (build fc853b) – May 31, 2017
Server jetty-6.1.x, java 1.8.0_141, HSQLDB, Windows Server 2016 (148.4 MB / 179.0 MB)
btrbver2
Postby benjmiller » Thu Aug 24, 2017 12:28 am
Bump, hard to believe we haven't had a response from the dev team.
benjmiller
Postby spiritofjerry » Tue Sep 05, 2017 5:23 pm
While a workaround is to disable FLAC transcoding for the web player, this is definitely a bug that needs attention. Bump.
spiritofjerry
Postby benjmiller » Sun Oct 01, 2017 3:28 am
Hoping this will be resolved at some point soon. Bump
benjmiller
Postby DJ Nativus » Mon Oct 02, 2017 12:43 am
I have had this issue for two years now. Seriously, no help?
DJ Nativus
Postby benjmiller » Tue Oct 17, 2017 11:41 pm
Bump. This is getting to be pretty frustrating that so many long time users are having similar issues with no response back from the team. I can't update Subsonic because the web player is broken, so what next? Find a Subsonic alternative? I have been using subsonic exclusively for many years. What a sad way to end things because of a broken update.
It seems obvious that when you combine the amount of people having this issue, and their the lack of response that they just don't give a shit.
benjmiller
Postby Jägs » Wed Oct 18, 2017 1:15 am
Just out of curiosity, have you checked out Airsonic https://airsonic.github.io/? It's a fork of a fork (fork of Subsonic to Libresonic, fork of Libresonic to Airsonic). I'd be curious to see if the problem exists there.
The reason I mention it is that it seems to be under much more active development than Subsonic. I'm currently running Subsonic and Airsonic in parallel.
Once they get a Debian build, I might jump ship, as it does not seem like much has happened with Subsonic since it went closed source.
Jägs
Postby benjmiller » Wed Oct 18, 2017 1:42 am
Thanks for the tip, I will check it out and let you know. How do I disable transcoding just for the web client?
EDIT: Airsonic works like a charm. Strongly recommended. It actually resolved a few longtime Subsonic issues.
benjmiller
Users browsing this forum: No registered users and 77 guests
