Help! Subsonic TransientDataAccessResourceException
Postby lneidorf » Tue Jul 04, 2017 11:51 pm
Hi there.
I'm a long-time subsonic user and have just ran into a problem for the first time.
Upon logging in to my subsonic home page, I get the error seen below.
I have updated both the Subsonic app and Java to the latest versions.
I should note that the server is running on a Mac with a recent version of OSX.
Any suggestions? I've seen recommendations for restoring the Subsonic database file, but have not been able to find the folder location.
Error
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
Java version   Oracle Corporation 1.8.0_25
Operating system   Mac OS X 10.11.6
Server   jetty-6.1.x
Memory   Used 64 of 89 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
   at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
   at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:698)
   at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:133)
   at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:137)
   at net.sourceforge.subsonic.dao.AbstractDao.namedQuery(AbstractDao.java:104)
   at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:280)
   at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:284)
   at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:185)
   at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:103)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:47)
   at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:59)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
   ... 65 more
lneidorf
Users browsing this forum: No registered users and 83 guests
