Failed to initialize database with Premium
Postby quatermass » Thu Jul 06, 2017 3:59 pm
My Subsonic has gone belly up on my Windows 10 set up.
I see from the Subsonic.log that it's my database.
[2017-07-06 16:43:26,201] INFO HsqlDaoHelper - Checking database schema.
[2017-07-06 16:43:26,915] ERROR HsqlDaoHelper - Failed to initialize database.
rg.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 70 S1000 General error java.lang.NullPointerException
Ending with :
[2017-07-06 16:43:27,347] INFO SettingsService - Java: 1.8.0_131, OS: Windows 10
[2017-07-06 16:43:27,623] INFO VersionService - Resolved local Subsonic version to: 6.1.1
I've no idea how to fix this. :?:
Is there a recovery program to run or what files do I need to restore from my backup?
Thanks for any help. I'd appreciate it.
Stuart Halliday
The Computer Man
quatermass
Re: Failed to initialize database with Premium
Postby Deviant0ne » Fri Jul 07, 2017 11:53 pm
I would try and remove the database and start over. Stop the Subsonic service, rename the C:\Subsonic\db to C:\Subsonic\db.old, start the Subsonic service and scan your library again to rebuild the database.
Deviant0ne
Postby quatermass » Sat Jul 08, 2017 8:10 pm
Thanks.
In the end I just restored all of c:\subsonic from a old backup. Just restoring the db folder didn't work for me.
Stuart Halliday
The Computer Man
quatermass
