Many random files not showing up
Postby skinygamer12 » Tue Jul 11, 2017 12:40 am
Problem:For some time now (I think it started after I updated the server, but I am not sure) various songs do not show up at all. I have files structured as music/artist/album and only a few songs of an album will show up, all in the same folder and same file type so there seems to be no reason for some to not show. Does not matter what playback application I use, the server cannot find them.
subsonic version:6.1.1 (build fc853b) – May 31, 2017
server version:jetty-6.1.x, java 1.8.0_121, HSQLDB, Windows 10 (68.0 MB / 141.3 M
java memory limit:512mb
last 10 log file lines:
[7/10/17 5:21:07 PM PDT]   INFO   MediaScannerService   Scanned media library with 13000 entries.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Scanned media library with 13250 entries.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Scanned media library with 13500 entries.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Scanned media library with 13703 entries.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Marking non-present files.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Marking non-present artists.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Marking non-present albums.
[7/10/17 5:21:08 PM PDT]   INFO   MediaScannerService   Completed media library scan.
[7/10/17 5:21:09 PM PDT]   INFO   PlaylistService   Starting playlist import.
[7/10/17 5:21:09 PM PDT]   INFO   PlaylistService   Completed playlist import.
skinygamer12
Re: Many random files not showing up
Postby scienex » Tue Jul 11, 2017 5:48 pm
been having this exact same problem
somehow, it seems my favourite tracks are especially prone to disappearing randomly, all of a sudden
but this may be because these are the files i look for the most ;)
i've been using the following workaround to get the lost tracks back in my database
don't get all excited though... it only seems to be a temporary solution
i've had to do this three times in a couple of weeks now
but at least, it works
1) Stop Subsonic
2) Backup your /var/subsonic/db/subsonic.script file
This file contains a handful of SQL statements that will be used later to recreate your users, media directory settings, etc.
3) Delete the contents of your /var/subsonic/db/ directory
4) Restore your subsonic.script file
5) Start Subsonic
6) In that your media library will now be empty, you'll want to go to "Settings..." "Media Folders..." and click "Scan media folders now"
scienex
Postby uberdork » Tue Jul 11, 2017 9:18 pm
Posting to confirm I'm having the same issue. I'm running 6.1.1 and I've noticed that new albums I add to my collection will get partially added. It will miss anywhere from 1 to multiple tracks. Scrobbling seems to have broken for me recently as well. I tried rolling back a version as well but it didn't help (ran db cleanup and rescanned after reinstalling 6.1).
uberdork
Postby bvdgrift » Wed Jul 12, 2017 11:45 am
+1
The last double CD I added contains 45 tracks of which 23 got added to the database (Version 6.1.1).
bvdgrift
Postby skinygamer12 » Thu Jul 13, 2017 9:32 pm
Thanks for the fix scienex! I guess I'll wait and see how long it lasts... Even a temporary fix is better than nothing!
skinygamer12
Postby uberdork » Thu Jul 13, 2017 11:22 pm
Does the fix posted above removed starred tracks? If so is there a way to back up your starred tracks or are they all stored in \subsonic\db\subsonic.data file?
uberdork
Postby scienex » Fri Jul 14, 2017 6:33 pm
sorry, haven't got a clue uberdork
i don't have any starred tracks
i like then all ;)
scienex
Postby Booster73 » Sat Jul 15, 2017 1:17 pm
Okay, I seemed to have fixed this same problem. What I did was make new folders for all my media, moved all my stuff into those new folders, enabled Subsonic to see them, and then did a media scan. Everything was back in Subsonic after that. After that, it's up to you, but I moved everything back to their original folders, deleted the dummy ones, and re-scanned. The only thing this did not fix was Playlists. Those were all still fucked, but at least now I can rebuild them. Hope this helps!
Booster73
Postby greatquux » Tue Jul 18, 2017 12:27 pm
Same problem here. This should really be a high priority bug!
greatquux
Postby greatquux » Tue Jul 18, 2017 12:49 pm
I also have an easy way to reproduce this - simply change some metadata on already scanned-in files, such as track numbers, and then do a rescan. After the rescan you will see the album there but changed tracks will all be missing.
greatquux
Postby owtbound » Tue Jul 18, 2017 3:42 pm
I have to confirm that I have this bug too... I've noticed that when I star FLAC files, they disappear almost immediately from all services accessing subsonic, but not MP3s. I also had an issue that broke podcasts that seemed related. I'd love to go premium, but I'm gonna wait until this is fixed :(
owtbound
Postby philh99 » Sun Jul 23, 2017 9:21 am
+ 1
philh99
Postby hairbag » Sun Jul 23, 2017 10:10 pm
This is a major problem with the windows 6.1.1 build. I constantly have database issues ever since updating to this build. It needs to be fixed asap, really takes away from the greatness that subsonic is.
hairbag
Postby skinygamer12 » Tue Aug 22, 2017 10:28 pm
Now the fix posted by scienex is not working.... I can't access subsonic at all through the browser when i do that.... Can anyone confirm if this issue is only on the Windows build? Will likely be switching to linux soon, and it would be awesome if this problem went away when i do... Otherwise will likely be using Madsonic or something....
skinygamer12
Postby deckardk » Wed Aug 23, 2017 5:10 am
skinygamer12 wrote:Now the fix posted by scienex is not working.... I can't access subsonic at all through the browser when i do that.... Can anyone confirm if this issue is only on the Windows build? Will likely be switching to linux soon, and it would be awesome if this problem went away when i do... Otherwise will likely be using Madsonic or something....
Having this same issue on a Linux server, songs disappear when metadata such as a song rating is updated.
deckardk
Users browsing this forum: No registered users and 41 guests
