Exception: org.springframework.dao.TransientDataAccessResour
Postby Ubra » Wed Aug 09, 2017 7:06 pm
I get this exception when I try to start Subsonic in my browser (Chrome);
Have used Subsonic for many years, have never had any problems.
Message PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
Java version Oracle Corporation 1.8.0_141
Operating system Windows 10 10.0
Server jetty-6.1.x
Memory Used 51 of 85 MB
Stack trace org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]; nested exception is java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:666)
at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:698)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:133)
at org.springframework.jdbc.core.namedparam.NamedParameterJdbcTemplate.query(NamedParameterJdbcTemplate.java:137)
at net.sourceforge.subsonic.dao.AbstractDao.namedQuery(AbstractDao.java:91)
at net.sourceforge.subsonic.dao.MediaFileDao.getNewestAlbums(MediaFileDao.java:260)
at net.sourceforge.subsonic.service.MediaFileService.getNewestAlbums(MediaFileService.java:266)
at net.sourceforge.subsonic.controller.HomeController.getNewest(HomeController.java:167)
at net.sourceforge.subsonic.controller.HomeController.handleRequestInternal(HomeController.java:85)
at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:29)
Caused by: java.sql.SQLException: S1000 General error java.util.NoSuchElementException in statement [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where type = ? and folder in (?) and present order by created desc limit ? offset ?]
... 65 more
Ubra
Re: Exception: org.springframework.dao.TransientDataAccessRe
Postby Paegus » Fri Aug 11, 2017 9:28 am
I had the same issue. You need to install OpenJDK 1.7
Paegus
