Subsonic & Sonos
Subsonic & Sonos
Postby RATTY » Wed Aug 09, 2017 8:15 pm
Had subsonic working with my Sonos fairly well but not having problems.
I have subsonic 6.1 on raspberry PI 3
connected to this is my music on a USB HD at lot of music ;-)
When I try to add the subsonic music service to my sonos controller app on my ipad i get
'there was a problem adding the subsonic acount a connection to subsonic could not be made'
The logs give this - any help appreciated!
8/9/17 7:56:13 PM UTC] INFO SonosService Found Sonos controllers: [192.168.0.25, 192.168.0.11]
[8/9/17 7:56:13 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.25, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/9/17 7:56:13 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.25: org.apache.http.client.HttpResponseException: Method Not Allowed
[8/9/17 7:56:13 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.11, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/9/17 7:56:13 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.11: org.apache.http.client.HttpResponseException: Method Not Allowed
[8/9/17 7:56:14 PM UTC] INFO NetworkService Deleted port mapping for port 4040
Regards
JD
RATTY
Re: Subsonic & Sonos
Postby RATTY » Sun Aug 13, 2017 4:15 pm
Update - still cannot get SOnos to add Subsonic Music Service
Wiped Pi SD card and put new DietPi image
Reinstalled subsonic
Tried resetting router
Turned of all Sonos and reset them up
Tried plex and can add that serive to Sonos
Put in subsonic licence key
In subsonic settings I enable Sonos and the music service name is Subsonic
This is what I get in subsonic log ............Can amyone help please!
8/13/17 4:10:15 PM UTC] INFO SonosService Found Sonos controllers: [192.168.0.13, 192.168.0.14, 192.168.0.11, 192.168.0.15, 192.168.0.12, 192.168.0.16]
[8/13/17 4:10:15 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.13, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:15 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.13: org.apache.http.client.HttpResponseException: Bad Request
[8/13/17 4:10:16 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.14, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:16 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.14: org.apache.http.client.HttpResponseException: Bad Request
[8/13/17 4:10:16 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.11, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:16 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.11: org.apache.http.client.HttpResponseException: Method Not Allowed
[8/13/17 4:10:16 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.15, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:16 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.15: org.apache.http.client.HttpResponseException: Bad Request
[8/13/17 4:10:16 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.12, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:16 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.12: org.apache.http.client.HttpResponseException: Bad Request
[8/13/17 4:10:16 PM UTC] INFO SonosServiceRegistration Enabling Sonos music service, using Sonos controller IP 192.168.0.16, SID 242, and Subsonic URL http://192.168.0.23:4040/ws/Sonos
[8/13/17 4:10:16 PM UTC] WARN SonosService Failed to enable/disable music service in Sonos controller 192.168.0.16: org.apache.http.client.HttpResponseException: Bad Request
RATTY
Postby RATTY » Tue Aug 15, 2017 6:01 pm
Well I've installed version 5 and I can now add subsonic to my sonos....this a bug?
The reason I went premium is for Sonos anyone else had this issue?
Cheers
John
RATTY
Postby RATTY » Thu Aug 24, 2017 5:31 pm
Started again today - clean card in pi - installed DietPi (very good btw) then installed subsonic 6.0
Cleared out all previous subsonic installs and cleared music service in Sonos
All seems to work OK now
RATTY
