Fresh Ubuntu install, Webapp won't connect
Postby cyril0 » Thu Sep 07, 2017 2:47 pm
Hello everyone
I just did a fresh Ubuntu 16.04 install and I installed Subsonic two different ways and neither way worked. First I tried to install the .deb manually after install a JDK but I couldn't get the webapp to connect. I then uninstalled it and just used apt-get to install it and I have the same problem. According to the logs subsonic is running but going to the webpage give me a 500 error. A ps shows me it is running on port 4040 but I get no web UI so it is pretty useless. Telneting to port 4040 responds so there is something happening.
the PS gives me
root 906 1 3 10:25 ? 00:00:25 java -Xmx900m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=0 -Dsubsonic.contextPath=/ -Dsubsonic.db= -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
I have another server on which subsonic is running and a PS looks like this
root 3321 1 1 Aug22 ? 04:54:54 java -Xmx1800m -Dsubsonic.home=/var/subsonic -Dsubsonic.host=0.0.0.0 -Dsubsonic.port=4040 -Dsubsonic.httpsPort=6060 -Dsubsonic.contextPath=/ -Dsubsonic.db= -Dsubsonic.defaultMusicFolder=/var/music -Dsubsonic.defaultPodcastFolder=/var/music/Podcast -Dsubsonic.defaultPlaylistFolder=/var/playlists -Djava.awt.headless=true -verbose:gc -jar subsonic-booter-jar-with-dependencies.jar
So both of the machines are doing the same thing.
I have no idea what is wrong, I have never had trouble installing Subsonic before. Any ideas?
Thank you
cyril0
Re: Fresh Ubuntu install, Webapp won't connect
Postby Tak-MK » Thu Sep 07, 2017 2:59 pm
Maybe disable SElinux?
Tak-MK
Postby cyril0 » Thu Sep 07, 2017 3:16 pm
OK
That resulted in an improvement still doesn't work but I have new info now. I will start looking in to this unless you have a suggestions
HTTP ERROR: 404
/error.jsp
RequestURI=/error.jsp
Caused by:
java.lang.NoClassDefFoundError: net/sourceforge/subsonic/filter/ParameterDecodingFilter$DecodingServletRequestWrapper
at net.sourceforge.subsonic.filter.ParameterDecodingFilter.doFilter(ParameterDecodingFilter.java:33)
at net.sourceforge.subsonic.filter.BootstrapVerificationFilter.doFilter(BootstrapVerificationFilter.java:61)
Caused by: java.lang.ClassNotFoundException: net.sourceforge.subsonic.filter.ParameterDecodingFilter$DecodingServletRequestWrapper
at jdk.internal.loader.BuiltinClassLoader.loadClass(java.base@9-internal/BuiltinClassLoader.java:366)
at jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(java.base@9-internal/ClassLoaders.java:184)
at java.lang.ClassLoader.loadClass(java.base@9-internal/ClassLoader.java:419)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:375)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
... 18 more
cyril0
Postby Tak-MK » Fri Sep 08, 2017 11:14 am
Try to disable it permanently at /etc/selinux/config, and changing the option to SELINUX=disabled. And then reboot the system or even reinstall subsonic, that 404 is a bit weird.
Tak-MK
Postby cyril0 » Sat Sep 09, 2017 12:57 am
I've done this and now I am back to the
This page isn’t working
192.168.0.189 is currently unable to handle this request.
HTTP ERROR 500
cyril0
Postby cyril0 » Sat Sep 09, 2017 1:06 am
If I am on the actual linux machine and use the browser to connect to subsonic I get a blank page and it throws no error. Chrome on my laptop throws the above error.
cyril0
Users browsing this forum: No registered users and 83 guests
