[Solved] SubSonic playlist skipping to next FLAC file
Postby pizzaazzip » Fri Sep 22, 2017 2:46 am
I think my title got cut off, it should say:
SubSonic playlist skipping to next FLAC file when playback is paused for more than ~5 minutes
OS: Windows 7 x64
Subsonic Version: 6.1.1 (build 2a8e8d) – May 31, 2017 Running on OS X El Capitan (10.11.6)
Clementine Version: 1.3.1-364-ga056a73
Since upgrading to the latest version of Subsonic, anytime I pause a .flac file for longer than a moment, resuming will cause the music to resume for about 20 seconds max and skip to the next song. On 6.1 of SubSonic I could come back Minutes/hours/days later and pick up exactly where I left off.
Because I am not able to skip ahead in .flac files as described in this issue I also filed today this can be quite frustrating. Like the other issue this does not occur with .mp3 files.
I initially posted this on the GitHub Page for Clementine thinking it was an issue with their program. I have since replicated this in other programs like Amarok for Windows 7 but not in dSub for Android. Also the program Ampache with uses the Subsonic API for third party apps and this issue reportedly does not occur in that setup.
Anyone else have this issue?
pizzaazzip
Re: SubSonic playlist skipping to next FLAC file when playba
Postby pizzaazzip » Thu Sep 28, 2017 7:12 pm
https://github.com/clementine-player/Cl ... ssues/5833
Turning off Encoding fixed both of my issues.
pizzaazzip
