sql: user lacks privilege or object not found
Postby iw2lsi » Tue Oct 17, 2017 8:11 pm
Hi...
I would like to alter my subsonic db (basically in order to import some album's comments) using an sql client instead of the web interface and/or web access to the db (http://localhost:4040/db.view)...
So far I can access the database via "hsqldb-sqltool madsonic", but when I try to run a query it fails...
ie:
>sql: select * from artist;
>user lacks privilege or object not found: ARTIST
my sqltool.rc looks like:
urlid subsonic
url jdbc:hsqldb:file:/var/subsonic/db
username sa
password
any ideas ?
Best Regards,
Giampaolo
iw2lsi
Re: sql: user lacks privilege or object not found
Postby Jägs » Tue Oct 17, 2017 11:32 pm
This may not be the route you want to go, but you could simply build a program to alter the database through the web interface. I developed app in Perl to export playlists for the purpose of backing them up, but there's no reason you couldn't alter the SQL statements to do updates as well:
http://forum.subsonic.org/forum/viewtopic.php?f=5&t=17436
Jägs
Postby iw2lsi » Wed Oct 18, 2017 6:30 pm
Hi Jags,
thanks a lot for your suggestion... I'm still struggling with the error I'm having trying to follow my original approach, but yeah... your solution seems very good!
Best Regards,
Giampaolo
iw2lsi
Postby iw2lsi » Thu Oct 19, 2017 4:53 pm
Hi...
I found the problem... it was just the url...
urlid subsonic
url jdbc:hsqldb:file:/var/subsonic/db/subsonic
username SA
password
Best Regards,
Giampaolo
iw2lsi
