Jukebox help request
Postby oshman6785 » Sun Oct 29, 2017 6:36 am
Problem Description:
Wow, where do I start. It looks like I have other problems that may be contributing, but after looking through multiple posts and suggestions, I've got just one player configured named Jukebox (all others have been deleted). Max bitrate is No limit, Player has a dynamic IP address and Control player automatically are both checked. My library is all flac so I have tested with mp3 audio active transcoding both checked and unchecked. And I still get no output when playing in jukebox mode.
My specs:
Playback Application and version: I'm just using the Subsonic web interface that displays when you log onto the server from a remote workstation.
Subsonic Version: 6.1.2 (build 09b0ab) – October 22, 2017
Server Version: jetty-6.1.x, java 1.8.0_152, HSQLDB, Linux (141.9 MB / 352.5 MB) (Java is Oracle, not openjdk)
Hardware Platform: Linux Ubuntu 16.04 LTS, completely up to date. Server configuration - headless
Java Memory Limit: I have added --max-memory=768 in my /etc/default/subsonic file
Output from ffmpeg -i:
ffmpeg -i /var/www/html/music/Led\ Zeppelin/1976-The\ Song\ Remains\ The\ Same/01-Rock\ And\ Roll\ \[Live\].flac
ffmpeg version 2.8.11-0ubuntu0.16.04.1 Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.4) 20160609
  configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
  libavutil      54. 31.100 / 54. 31.100
  libavcodec     56. 60.100 / 56. 60.100
  libavformat    56. 40.101 / 56. 40.101
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 40.101 /  5. 40.101
  libavresample   2.  1.  0 /  2.  1.  0
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.101 /  1.  2.101
  libpostproc    53.  3.100 / 53.  3.100
Input #0, flac, from '/var/www/html/music/Led Zeppelin/1976-The Song Remains The Same/01-Rock And Roll [Live].flac':
  Metadata:
    TRACKTOTAL      : 15
    TITLE           : Rock And Roll [Live];Rock And Roll [Live]
    ARTIST          : Led Zeppelin;Led Zeppelin
    disc            : 01
    DATE            : 1976;1976
    ALBUM           : The Song Remains The Same;The Song Remains The Same
    track           : 01
    GENRE           : Rock;Rock
    DISCID          : 890e2e0a
  Duration: 00:03:56.35, start: 0.000000, bitrate: 1032 kb/s
    Stream #0:0: Audio: flac, 44100 Hz, stereo, s16
Troubleshooting Steps:
aplay -L
   iec958:CARD=Intel,DEV=0
    HDA Intel, STAC9271X Digital
    IEC958 (S/PDIF) Digital Audio Output
speaker-test -Diec958:Intel -c 2 -l 2 cycles through the front speakers
lspci -s 00:1b.0 -v
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 02)
        Subsystem: Gateway, Inc. 82801H (ICH8 Family) HD Audio Controller
        Flags: bus master, fast devsel, latency 0, IRQ 34
        Memory at e2320000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [50] Power Management version 2
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [130] Root Complex Link
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
Following some hints in post: http://forum.subsonic.org/forum/viewtopic.php?f=2&t=2038&start=30, I compiled and ran the audioDevList applet and those results are
   Available mixers:
   default [default]
   Intel [plughw:0,0]
   Intel [plughw:0,1]
   Intel [plughw:0,2]
   Port Intel [hw:0]
I can run cmus directly on the server and play flac files through the stereo. When trying to cycle through the available mixers that are listed from the audioDevList applet (when added to the /usr/share/subsonic/subsonic.sh script) none of the options results in sound output when trying to play.
The section of code from the subsonic.sh script (of course it's still set to the last one from the audioDevList list of output mixers...)
${JAVA} -Xmx${SUBSONIC_MAX_MEMORY}m \
  -Dsubsonic.home=${SUBSONIC_HOME} \
  -Dsubsonic.host=${SUBSONIC_HOST} \
  -Dsubsonic.port=${SUBSONIC_PORT} \
  -Dsubsonic.httpsPort=${SUBSONIC_HTTPS_PORT} \
  -Dsubsonic.contextPath=${SUBSONIC_CONTEXT_PATH} \
  -Dsubsonic.db="${SUBSONIC_DB}" \
  -Dsubsonic.defaultMusicFolder=${SUBSONIC_DEFAULT_MUSIC_FOLDER} \
  -Dsubsonic.defaultPodcastFolder=${SUBSONIC_DEFAULT_PODCAST_FOLDER} \
  -Dsubsonic.defaultPlaylistFolder=${SUBSONIC_DEFAULT_PLAYLIST_FOLDER} \
  -Djava.awt.headless=true \
  '-Djavax.sound.sampled.SourceDataLine=#Port Intel [hw:0]' \
  -verbose:gc \
  -jar subsonic-booter-jar-with-dependencies.jar > ${LOG} 2>&1 &
Last ten log file lines:
[10/29/17 1:53:28 AM EDT]   INFO   HsqlDaoHelper   Checking database schema.
[10/29/17 1:53:30 AM EDT]   INFO   HsqlDaoHelper   Done checking database schema.
[10/29/17 1:53:30 AM EDT]   INFO   SettingsService   Java: 1.8.0_152, OS: Linux
[10/29/17 1:53:30 AM EDT]   INFO   VersionService   Resolved local Subsonic version to: 6.1.2
[10/29/17 1:53:31 AM EDT]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Oct 29 03:00:00 EDT 2017
[10/29/17 1:53:31 AM EDT]   INFO   UPnPService   Starting UPnP service...
[10/29/17 1:53:31 AM EDT]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Sun Oct 29 01:58:31 EDT 2017
[10/29/17 1:53:32 AM EDT]   INFO   UPnPService   Enabling UPnP/DLNA media server
[10/29/17 1:53:32 AM EDT]   INFO   UPnPService   Starting UPnP service - Done!
[10/29/17 1:53:38 AM EDT]   INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[10/29/17 1:53:41 AM EDT]   WARN   NetworkService   No UPnP router found.
[10/29/17 1:53:50 AM EDT]   INFO   VersionService   Resolved latest Subsonic final version to: 6.1.2
[10/29/17 1:53:50 AM EDT]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
[10/29/17 1:54:13 AM EDT]   INFO   JukeboxService   osh starting jukebox for "2005-Under Cover/02-In My Life.flac"
[10/29/17 1:56:11 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "2005-Under Cover/02-In My Life.flac"
[10/29/17 1:56:11 AM EDT]   INFO   JukeboxService   osh starting jukebox for "Led Zeppelin III/01-Immigrant Song.mp3"
[10/29/17 1:58:31 AM EDT]   INFO   PodcastService   Starting scheduled Podcast refresh.
[10/29/17 1:58:31 AM EDT]   INFO   PodcastService   Completed scheduled Podcast refresh.
[10/29/17 1:58:36 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "Led Zeppelin III/01-Immigrant Song.mp3"
[10/29/17 1:58:36 AM EDT]   INFO   JukeboxService   osh starting jukebox for "Led Zeppelin III/02-Friends.mp3"
[10/29/17 2:02:29 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "Led Zeppelin III/02-Friends.mp3"
[10/29/17 2:02:29 AM EDT]   INFO   JukeboxService   osh starting jukebox for "Led Zeppelin III/03-Celebration Day.mp3"
[10/29/17 2:05:58 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "Led Zeppelin III/03-Celebration Day.mp3"
[10/29/17 2:05:58 AM EDT]   INFO   JukeboxService   osh starting jukebox for "Led Zeppelin III/04-Since I've Been Loving You.mp3"
[10/29/17 2:13:02 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "Led Zeppelin III/04-Since I've Been Loving You.mp3"
[10/29/17 2:13:02 AM EDT]   INFO   JukeboxService   osh starting jukebox for "2011-Reanimate- The Covers EP/01-Slave To The Grind (Skid Row cover).mp3"
[10/29/17 2:16:33 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "2011-Reanimate- The Covers EP/01-Slave To The Grind (Skid Row cover).mp3"
[10/29/17 2:16:33 AM EDT]   INFO   JukeboxService   osh starting jukebox for "2011-Reanimate- The Covers EP/02-Bad Romance (Lady Gaga cover).mp3"
[10/29/17 2:20:42 AM EDT]   INFO   JukeboxService   osh stopping jukebox for "2011-Reanimate- The Covers EP/02-Bad Romance (Lady Gaga cover).mp3"
[10/29/17 2:20:42 AM EDT]   INFO   JukeboxService   osh starting jukebox for "2011-Reanimate- The Covers EP/03-Hunger Strike (Temple Of The Dog cover).mp3"
Logs:
subsonic.log
[2017-10-29 01:53:28,847] INFO HsqlDaoHelper - Checking database schema.
[2017-10-29 01:53:30,712] INFO HsqlDaoHelper - Done checking database schema.
[2017-10-29 01:53:30,878] INFO SettingsService - Java: 1.8.0_152, OS: Linux
[2017-10-29 01:53:30,902] INFO VersionService - Resolved local Subsonic version to: 6.1.2
[2017-10-29 01:53:31,520] INFO MediaScannerService - Automatic media library scanning scheduled to run every 1 day(s), starting at Sun Oct 29 03:00:00 EDT 2017
[2017-10-29 01:53:31,703] INFO UPnPService - Starting UPnP service...
[2017-10-29 01:53:31,962] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Sun Oct 29 01:58:31 EDT 2017
[2017-10-29 01:53:32,588] INFO UPnPService - Enabling UPnP/DLNA media server
[2017-10-29 01:53:32,589] INFO UPnPService - Starting UPnP service - Done!
[2017-10-29 01:53:38,328] INFO BootstrapVerificationFilter - Servlet container: jetty-6.1.x
[2017-10-29 01:53:41,722] WARN NetworkService - No UPnP router found.
[2017-10-29 01:53:50,657] INFO VersionService - Resolved latest Subsonic final version to: 6.1.2
[2017-10-29 01:53:50,658] INFO VersionService - Resolved latest Subsonic beta version to: 6.1.beta2
[2017-10-29 01:54:13,393] INFO JukeboxService - osh starting jukebox for "2005-Under Cover/02-In My Life.flac"
[2017-10-29 01:56:11,735] INFO JukeboxService - osh stopping jukebox for "2005-Under Cover/02-In My Life.flac"
[2017-10-29 01:56:11,759] INFO JukeboxService - osh starting jukebox for "Led Zeppelin III/01-Immigrant Song.mp3"
[2017-10-29 01:58:31,959] INFO PodcastService - Starting scheduled Podcast refresh.
[2017-10-29 01:58:31,960] INFO PodcastService - Completed scheduled Podcast refresh.
[2017-10-29 01:58:36,229] INFO JukeboxService - osh stopping jukebox for "Led Zeppelin III/01-Immigrant Song.mp3"
subsonic_sh.log
10395 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization started
10396 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@74ecacc3: display name [WebApplicationContext for namespace 'subsonic-servlet']; startup date [Sun Oct 29 01:53:36 EDT 2017]; parent: org.springframework.web.context.support.XmlWebApplicationContext@2d1ef81a
10396 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/subsonic-servlet.xml]
10461 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Bean factory for application context [org.springframework.web.context.support.XmlWebApplicationContext@74ecacc3]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1687eb01
10552 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1687eb01: defining beans [leftController,artistsController,rightController,statusController,mainController,playlistController,playlistsController,bookmarksController,importPlaylistController,topController,helpController,moreController,uploadController,lyricsController,allmusicController,podcastController,podcastChannelsController,internetRadioController,internetRadioStreamController,podcastChannelController,podcastReceiverAdminController,setMusicFileInfoController,shareManagementController,setRatingController,randomPlayQueueController,changeCoverArtController,nowPlayingController,starredController,searchController,settingsController,playerSettingsController,dlnaSettingsController,sonosSettingsController,shareSettingsController,musicFolderSettingsController,networkSettingsController,transcodingSettingsController,internetRadioSettingsController,podcastSettingsController,videoConversionSettingsController,generalSettingsController,advancedSettingsController,personalSettingsController,avatarUploadController,userSettingsController,passwordSettingsController,homeController,editTagsController,playQueueController,coverArtController,artistImageController,captionsController,avatarController,statusChartController,userChartController,m3uController,streamController,hlsController,segmentController,videoPlayerController,videoConverterController,externalPlayerController,downloadController,premiumSettingsController,multiController,wapController,restController,dbController,premiumSettingsValidator,userSettingsValidator,passwordSettingsValidator,urlMapping,messageSource,themeSource,themeResolver,viewResolver]; parent: org.springframework.beans.factory.support.DefaultListableBeanFactory@18df8434
[GC (Allocation Failure)  174977K->57496K(285184K), 0.0391242 secs]
11685 [main] INFO org.springframework.web.servlet.DispatcherServlet - FrameworkServlet 'subsonic': initialization completed in 1290 ms
11702 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
11751 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
11764 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
11803 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
[GC (Allocation Failure)  188056K->58194K(279040K), 0.0464027 secs]
24678 [btpool0-7] INFO org.directwebremoting.log.startup - Starting: DwrServlet v3.0.0-FINAL on jetty-6.1.x / JDK 1.8.0_152 from Oracle Corporation at
25266 [btpool0-7] INFO org.directwebremoting.log.startup - Starting: Using container abstraction org.directwebremoting.server.servlet2.Servlet24ContainerAbstraction
25282 [btpool0-7] INFO org.directwebremoting.servlet.UrlProcessor - Probably not an issue: the url:/gi.js (org.directwebremoting.gi.GiHandler) Handler is not available. This is only an problem if you wanted to use it.
[GC (Allocation Failure)  210770K->72980K(302592K), 0.0916998 secs]
[GC (Metadata GC Threshold)  139579K->72453K(322048K), 0.0819020 secs]
[Full GC (Metadata GC Threshold)  72453K->66575K(360960K), 0.4322244 secs]
[GC (Allocation Failure)  237071K->68427K(363520K), 0.0093998 secs]
(Here's a good place to ask, what do the [GC (Allocation Failure) ...] and [Full GC (Metadata GC Threshold) ...] errors mean? How do I resolve them?)
oshman6785
Re: Jukebox help request
Postby oshman6785 » Mon Nov 06, 2017 11:27 pm
--bump--
Anything? Even a suggestion would be helpful.
oshman6785
Postby oshman6785 » Wed Nov 22, 2017 4:05 am
Just a quick note for anyone else that may run into this issue. It appears to be a permissions issue or something similar. My login can play directly to the stereo using the cmus app. So I know the card is good and properly configured. Subsonic doesn't work. I changed ownership of the subsonic folder to me, then set the daemon to run as me, and now it works and plays in jukebox mode as expected.
I need to dig a little deeper and see why my subsonic user fails but my login runs fine.
oshman6785
