Music Missing after Update to 6.1.2
Postby poorlex » Mon Oct 30, 2017 3:42 am
Problem Description: Music has gone missing from my Index for no reason. Albums and artists that used to populate and are still in my local folders are no longer showing up in Subsonic. I was also having issues with the Android Subsonic App, which tipped me off to some of these issues. I was playing a particular album and it played about 1/2 of the songs then got stuck on a song saying it was downloading, but stuck at 0kb forever.
Troubleshooting Steps: I have uninstalled and re-installed 6.1.1, 6.1 and 6.1.2 multiple times. I've powercycled the computer but that didn't help either
Playback Application and version: Web Client and Andriod App (Subsonic Music Streamer)
Subsonic Version: 6.1.2 (build 09b0ab) – October 21, 2017
Server Version: jetty-6.1.x, java 1.8.0_151, HSQLDB, Windows 7 (98.7 MB / 145.0 MB)
Hardware Platform: Windows 7 Home Premium
Java Memory Limit: (Windows: found in the Subsonic Agent in the taskbar) -----> I am not clear on what this instruction is
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the o
Last ten log file lines:
[10/29/17 11:26:44 PM EDT]    INFO   HsqlDaoHelper   Checking database schema.
[10/29/17 11:26:45 PM EDT]    INFO   HsqlDaoHelper   Done checking database schema.
[10/29/17 11:26:46 PM EDT]    INFO   SettingsService   Java: 1.8.0_151, OS: Windows 7
[10/29/17 11:26:46 PM EDT]    INFO   VersionService   Resolved local Subsonic version to: 6.1.2
[10/29/17 11:26:46 PM EDT]    INFO   PlayerDao   Deleted 2 player(s) that haven't been used after Wed Aug 30 23:26:46 EDT 2017
[10/29/17 11:26:47 PM EDT]    INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Mon Oct 30 03:00:00 EDT 2017
[10/29/17 11:26:47 PM EDT]    INFO   UPnPService   Starting UPnP service...
[10/29/17 11:26:47 PM EDT]    WARN   PodcastService   Failed to resolve media file ID for podcast channel 'RZIM: Let My People Think Broadcasts': org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
[10/29/17 11:26:48 PM EDT]    INFO   PodcastService   Automatic Podcast update scheduled to run every 1 hour(s), starting at Sun Oct 29 23:31:48 EDT 2017
[10/29/17 11:26:48 PM EDT]    INFO   UPnPService   Disabling UPnP/DLNA media server
[10/29/17 11:26:48 PM EDT]    INFO   UPnPService   Starting UPnP service - Done!
[10/29/17 11:26:57 PM EDT]    WARN   NetworkService   Failed to create port forwarding.
[10/29/17 11:27:16 PM EDT]    INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[10/29/17 11:27:18 PM EDT]    INFO   VersionService   Resolved latest Subsonic final version to: 6.1.2
[10/29/17 11:27:18 PM EDT]    INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
[10/29/17 11:31:48 PM EDT]    INFO   PodcastService   Starting scheduled Podcast refresh.
[10/29/17 11:31:48 PM EDT]    WARN   PodcastService   Failed to resolve media file ID for podcast channel 'RZIM: Let My People Think Broadcasts': org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
[10/29/17 11:31:48 PM EDT]    INFO   PodcastService   Completed scheduled Podcast refresh.
[10/29/17 11:31:48 PM EDT]    WARN   PodcastService   Failed to download cover art for podcast channel 'This American Life': org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
[10/29/17 11:31:49 PM EDT]    INFO   PodcastService   Created Podcast episode 170 – Minor Punitive Heart Attacks[
When i tried refreshing my running a new scan of the media folders and then refreshing the index this is the error I received:
Exception    org.springframework.dao.TransientDataAccessResourceException
Message    PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
Java version    Oracle Corporation 1.8.0_151
Operating system    Windows 7 6.1
Server    jetty-6.1.x
Memory    Used 81 of 145 MB
Stack trace    org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]; nested exception is java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   at net.sourceforge.subsonic.dao.AbstractDao.update(AbstractDao.java:68)
   at net.sourceforge.subsonic.dao.MediaFileDao.createOrUpdateMediaFile(MediaFileDao.java:147)
   at net.sourceforge.subsonic.service.MediaFileService.updateChildren(MediaFileService.java:385)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:183)
   at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:158)
   at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
   at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
   at net.sourceforge.subsonic.controller.ArtistsController.handleRequestInternal(ArtistsController.java:112)
Caused by: java.sql.SQLException: S1000 General error java.lang.NullPointerException in statement [update media_file set folder=?,type=?,format=?,title=?,album=?,artist=?,album_artist=?,disc_number=?,track_number=?,year=?,genre=?,bit_rate=?,variable_bit_rate=?,duration_seconds=?,file_size=?,width=?,height=?,cover_art_path=?,parent_path=?,play_count=?,last_played=?,comment=?,changed=?,last_scanned=?,children_last_updated=?,present=?, version=? where path=?]
   ... 64 more
poorlex
Re: Music Missing after Update to 6.1.2
Postby alphawave7 » Mon Oct 30, 2017 7:33 am
That Java version rolled on Oct 19...betting the update didn't properly shut down the db....S1000 errors are often caused my corrupted db from a java update while db was still running.
Postby poorlex » Mon Oct 30, 2017 11:22 pm
alphawave7 wrote:That Java version rolled on Oct 19...betting the update didn't properly shut down the db....S1000 errors are often caused my corrupted db from a java update while db was still running.
I'm a bit of a beginner when it comes to Java and know nothing about databases, yet.
Do you have any suggestions on how I can clear it up?
poorlex
