disable markup in comments
Postby iw2lsi » Thu Nov 09, 2017 9:53 pm
Hi all!
is there a way to completely disable markup sequences for the comments ?
I'm importing comments from an existing database, but most of them have some fancy graphics made by sequences of underscore, tilda chars etc etc that are interpreted by subsonic in a "wrong" way... even if this is a very nice feature, having just a plain text would be better in my case :D
Best Regards,
Giampaolo
iw2lsi
Re: disable markup in comments
Postby iw2lsi » Mon Nov 13, 2017 8:37 pm
BTW... I've solved the problem in a very dirty way... by replacing with a regex the token used by subsonic for the markup (-,~,_ etc) with some "similar" unicode glyphs...
it's awful... but it works perfectly :D
Best Regards,
Giampaolo
iw2lsi
