Error http 503
Error http 503
Postby psychiktv » Sun Nov 12, 2017 7:08 pm
Hi, since the last os update, the subsonic server is stuck ...
Problem Description: since the latest apple security update for 10.12.6, I have the 503 error
Playback Application and version: web, isub and play:sub
Subsonic Version: 6.1.3
Server Version: (copy/paste from the "About" screen in the Subsonic Web Interface)
Hardware Platform: Mac Mini mid 2011 running 10.12.6
Any suggestions ?
thanks a lot
PTV
psychiktv
Re: Error http 503
Postby toolman » Sun Nov 12, 2017 7:20 pm
Did you check if your server is still running?
If so, did you check if you can reach it from the server itself? ( http://localhost:4040 if you're using the default settings.)
Did you check what Subsonic says about the connectivity? ( Settings >> Network .) Do you see Status: Successfully registered web address.
Did you try restarting the server?
toolman
Re: Error http 503
Postby psychiktv » Sun Nov 12, 2017 7:46 pm
I restarted the application several times, I reinstalled the server, even rebooted the computer, but nothing worked.
The only page I can access is the "subsonic control panel" which says :
Started on : Nov 12, ..
Memory used : 18MB
No error Message
Server adress is http://localhost:4040/
I also have the 503 error when trying to connect to http://localhost:4040/
thanks !
psychiktv
Re: Error http 503
Postby psychiktv » Sun Nov 12, 2017 8:54 pm
it was due to a database corruption. I just had to remove the subsonic/db folder...
psychiktv
Re: Error http 503
Postby toolman » Sun Nov 12, 2017 10:28 pm
OK, Sh*t does happen. Anyway, thanks for reporting back. Might help others in solving their problem.
toolman
Users browsing this forum: No registered users and 78 guests
