New install - read in my media files but no songs showing up
Postby bushidoka » Sat Dec 09, 2017 1:52 pm
Hi folks,
I just installed the latest version from the website - 6.1.3 and I used the RPM and installed it on CentOS 7.3.1611
I went to localhost:4040 and all looks good.
I point it at my media directory and get it to scan.
The message at the top right counted up as it was scanning my media.
And now nothing - no songs show up anywhere.
"Recently added" is completely blank.
So is "All:
Not sure what to do next to debug. I restarted the service and same thing.
thanks,
-Alan
bushidoka
Re: New install - read in my media files but no songs showin
Postby bushidoka » Sat Dec 09, 2017 1:56 pm
Oh I also went through the FAQs and did not see this there
bushidoka
Postby toolman » Sat Dec 09, 2017 4:13 pm
Did you make sure that the account you are using has the correct priviliges to acces your music-folders?
You might presume that the admin account has the privilege automatically, but in Subsonic that is not so.
toolman
Postby bushidoka » Sat Dec 09, 2017 6:33 pm
It warned me that the daemon was running as root and I did not change that yet, so it should have permissions.
bushidoka
Postby toolman » Sat Dec 09, 2017 8:54 pm
Ok, but did you check Settings >> Users >> (Account you are using) >> Allow access to these media folders: ?
If you have no acces to mediafolders, you will not be able to play anything, so if you don't have acces to any media folder you will have to change that.
No matter what Subsonic tells you.
toolman
Postby bushidoka » Sat Dec 09, 2017 9:42 pm
That did it - thanks
bushidoka
