Domain name not updated under Linux
Postby GGC » Wed Dec 20, 2017 9:59 am
Hi all
My Domain name is not updated (ie the dynamic IP address linked to the domain name does not change when the IP address changes) when subsonic is running under Linux Mint 18.3. This happens also without firewall.
Same version of Subsonic works properly under Win 10.
Any suggestions? Thanks.
License Subsonic Premium (expires May 29, 2018)
Version 6.1.3 (build e408c9) – October 31, 2017
Server jetty-6.1.x, java 1.8.0_151, HSQLDB, Linux (78.7 MB / 133.0 MB)
GGC
Re: Domain name not updated under Linux
Postby toolman » Wed Dec 20, 2017 11:28 am
And what does the logfile tell you?
Did you check under Settings > Network what status is indicated?
Did you rely on Subsonic to set the portforwarding or did you do it manually?
Does your Server have a static ip-adress in your LAN?
Did you check the settings in your router?
toolman
Users browsing this forum: No registered users and 93 guests
