Problem with saving settings
Postby swischeze » Tue Apr 28, 2009 9:34 pm
When I try to save the settings for my server, it gives me a pop-up window that says "Failed to write to file C:\...\Subsonic\subsonic-service.exe.vmoptions. subsonic-service.exe.vmoptions (Access is denied.)"
Any ideas on how I can fix this? Thanks!
swischeze
Postby mixmaster » Wed Apr 29, 2009 1:13 am
I got the same thing. It's cuz you're not running the right context. What I did is just went to the directory, set the perms for my user to edit the file and did it manually with notepad. I needed up bump up my memory usage otherwise the service would keep crashing.
________
mixmaster
