Failed to register web address. 404 Not Found (IOException)
Postby Ch151 » Tue Jan 16, 2018 1:59 pm
Hi there I have recently started getting this error on my server when using the subsonic address Failed to register web address. 404 Not Found (IOException)
any ideas please I have rebooted the server a couple of times but still no luck
thanks in advance
Ch151
Re: Failed to register web address. 404 Not Found (IOExcepti
Postby toolman » Tue Jan 16, 2018 6:31 pm
You might check if your server really is online ( http://downforeveryoneorjustme.com/ )
If your server appears to be off line you might try setting up the portforwarding manually. If you have all ready done that and it is no solution, delete the portforwarding, reboot your router and configure the portforwarding again.
toolman
