Port Forwarding issue
Postby millmoss » Tue Feb 06, 2018 5:47 am
Christ I thought this would be simple enough to figure out.
First I tried automatic. That seemed to work internally to subsonic. But I bought two different IOS apps and neither could connect.
Next I disabled the automatic and tried manual. Based on the instructions at portforward.com, I added 80, and 4040. Both went in to the router admin without a problem.
Still cannot connect. Play:sub says error communicating with server. iSub says request timed out.
Thanks in advance for any help.
millmoss
Re: Port Forwarding issue
Postby millmoss » Tue Feb 06, 2018 5:51 am
Also, in the subsonic settings, it now says:
Update: Status is: Successfully registered web address.
So it seems like on my computer end, things are good. But I still cannot connect with either of the apps.
millmoss
Users browsing this forum: No registered users and 136 guests
