https behind NGINX reverse proxy, connection refused
Postby lightnin » Sat Feb 17, 2018 5:44 pm
Greetings -
I'm trying to setup Subsonic with https using a letsencrypt cert, following the tutorial here:
https://www.linuxbabe.com/ubuntu/instal ... untu-16-04
The nginx configuration in http works fine. However, the https config results in no response.
In both, I'm running subsonic with the following:
SUBSONIC_ARGS="--port=4040 --max-memory=200"
Though I have tried with https=4443, but that doesn't work. Whenever I am using the https config, the redirect function for https works, but the connection is refused (and the browser reports no cert information.)
Help and suggestions appreciated!
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
Nginx config: (without customization for my domain)
server {
listen 80;
server_name subsonic.your-domain.com;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
ssl_protocols TLSv1.1 TLSv1.2;
ssl_certificate /etc/letsencrypt/live/subsonic.your-domain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/subsonic.your-domain.com/privkey.pem;
location / {
proxy_pass http://127.0.0.1:4040;
proxy_set_header Host $http_host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_redirect http:// https://;
location ~ /.well-known/acme-challenge {
root /var/www/subsonic/;
allow all;
lightnin
Re: https behind NGINX reverse proxy, connection refused
Postby lightnin » Sun Feb 18, 2018 7:21 am
It's often something simple. :)
I had been forwarding port 80 through the router, but didn't realize that I needed to add a forward rule for https, 443, as well. Otherwise nginx 301 redirects incoming requests on port 80 straight to 443, which is not open, so it doesn't work. Doh.
lightnin
Users browsing this forum: No registered users and 74 guests
