DLNA Doesn't work
DLNA Doesn't work
Postby dtacheron » Sun Feb 25, 2018 4:56 pm
Subsonic last version (02/25/2018). Ubuntu 16.04 LTS.
uname -a
Linux NAS 4.4.0-116-generic #140-Ubuntu SMP Mon Feb 12 21:23:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
java -version
openjdk version "1.8.0_151"
OpenJDK Runtime Environment (build 1.8.0_151-8u151-b12-0ubuntu0.16.04.2-b12)
OpenJDK 64-Bit Server VM (build 25.151-b12, mixed mode)
DLNA player and Subsonic are on the same LAN.
i can't read music with a dlna player (i tried with 2 differents players that work with Windows 10 Media Streaming).
the player browse the files correctly but when you try to play a song, it iterates over all songs without producing music.
[2018-02-25 16:54:11,385] INFO FolderBasedContentDirectory - UPnP request - objectId: 0, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:54:23,459] INFO FolderBasedContentDirectory - UPnP request - objectId: folder-1, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:54:49,182] INFO FolderBasedContentDirectory - UPnP request - objectId: folder-41, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:54:55,670] INFO FolderBasedContentDirectory - UPnP request - objectId: folder-872, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:55:11,139] INFO FolderBasedContentDirectory - UPnP request - objectId: folder-44, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:55:13,976] INFO FolderBasedContentDirectory - UPnP request - objectId: folder-951, browseFlag: BrowseDirectChildren, filter: *, firstResult: 0, maxResults: 64
[2018-02-25 16:55:17,893] WARN SecurityService - Unauthenticated access attempt: You Could Have It So Much Better
i tried with mp3 files (no transcoding) and other files.
i play songs normaly with the web interface
video here : https://drive.google.com/file/d/1bLRyL6JEJsRaEybPb82xJtmrAsXCQ2fm/view?usp=sharing
detail setup, logs etc here :https://drive.google.com/file/d/1F3SqHtl0P4kdx0Bxor2Q-2NnbBROn367/view?usp=sharing
It looks like a bug.
Thanks 4 help.
PS :
i'll try to increase the log verbosity (found the war, i'll take a look at).
dtacheron
Re: DLNA Doesn't work
Postby dtacheron » Sun Feb 25, 2018 5:09 pm
Logs are here : https://drive.google.com/file/d/1i1mXpFkBC0hLwxKhjk_SlbUJOWS7rYQL/view?usp=sharing
it seems that there is a problem with memory allocation
java.lang.NullPointerException
at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:80)
at net.sourceforge.subsonic.controller.StreamController.handleRequest(StreamController.java:66)
i'll re-try with a tail on the log file
dtacheron
Postby dtacheron » Sun Feb 25, 2018 5:16 pm
ok, problem is here (net.sourceforge.subsonic.controller.StreamController)
Player player = this.playerService.getPlayer(request, response, false, true);
User user = this.securityService.getUserByName(player.getUsername());
try
if (!user.isStreamRole())
response.sendError(403, "Streaming is forbidden for user " + user.getUsername());
return null;
NullPointerException.
user object seems not allocated.
dtacheron
Postby dtacheron » Sun Feb 25, 2018 5:42 pm
It works with subsonic android app.
it seems like you need to authenticate, and that dlna player not designed specifically with this in mind will not work properly ?
dtacheron
Postby intangir » Wed Aug 08, 2018 8:12 pm
I had the same issue and found the answer:
login as admin, goto USERS
goto GUEST, set it to be able to play files, and give it access to your folders
also you can goto players, and look under the guest user, if you see that the last time guest was on was when you tried your DLNA/UPnP client, then its surely using guest access
i set it and it worked for me
intangir
Users browsing this forum: No registered users and 79 guests
