New Ubuntu install......Folder not Found
Postby g0rsq » Wed Feb 28, 2018 10:27 pm
I have just installed Subsonic on my Ubuntu 16.04 server.
I can connect to Subsonic via my Ubuntu desktop ([server ip]:4040) but when I go to "Settings" "Media Folders" (as administrator) I can not get Subsonic to recognize the path to my music folder, and get "folder not found" in red.
My music folder is mounted /mnt/nas/media/music on the server
I enter /mnt/nas/media/music in the folder box
The only entry that will not give "Folder not found" is /mnt/
When I check permissions:-
ls -la /mnt/nas/media/music
result
total 228
drwxrwsr-x 57 g0rsq music   4096 Feb 28 19:31 .
drwxrw-r--  4 g0rsq nogroup 4096 Jan 21 15:31 ..
drwxrwxrwx  7 g0rsq music   4096 Jan 25 22:17 Alice Russell
drwxrwxrwx  3 g0rsq music   4096 Jan 25 22:17 Alicia Keys
drwxrwxrwx  3 g0rsq music   4096 Jan 25 22:17 Amy Winehouse
drwxrwxrwx  4 g0rsq music   4096 Jan 25 22:17 Annie Lennox
drwxrwxrwx  5 g0rsq music   4096 Jan 25 22:17 Belinda Carlisle
etc
Owner of the /var/subsonic folder is a user "subsonic" and the user has been changed to subsonic in the /etc/default/subsonic file
I also added the user "subsonic" to the "music" group
root@ubuntu-server:~# ls -la /var/subsonic
total 52
drwxr-x---  6 subsonic subsonic  4096 Feb 28 20:50 .
drwxr-xr-x 14 root     root      4096 Feb 28 20:04 ..
drwxr-xr-x  2 subsonic subsonic  4096 Feb 28 20:50 db
drwxr-xr-x  3 subsonic subsonic  4096 Feb 28 20:05 jetty
drwxr-xr-x  7 subsonic subsonic  4096 Feb 28 20:05 lucene2
-rw-r--r--  1 subsonic subsonic  5711 Feb 28 22:06 subsonic.log
-rw-r--r--  1 subsonic subsonic   357 Feb 28 22:06 subsonic.properties
-rw-r--r--  1 subsonic subsonic 14186 Feb 28 22:07 subsonic_sh.log
drwxr-xr-x  2 subsonic subsonic  4096 Feb 28 20:04 transcode
Both UFW firewalls have been disabled
Any idea how to get Subsonic to see my Music folders?
peter
g0rsq
Re: New Ubuntu install......Folder not Found
Postby toolman » Wed Feb 28, 2018 11:07 pm
I'm not familiar with Linux / Ubuntu but the error "Folder Not Found" means that the user that's running the Subsonic service doesn't have sufficient permissions to acces the folder you specified.
Since you don't get the error when you only specify the "top"-folder (MNT) one might assume that there's a problem with the permissions in the subfolders OR you made a typo....
toolman
Postby g0rsq » Thu Mar 01, 2018 4:30 pm
toolman
thanks for you response.
I too think it is a permissions thing, but for the life of me can not figureout what is wrong. Maybe someone with Ubuntu experience can help further!
My folder structure is:-
/mnt/nas/media/music/"artist"
drwxrw-r--   4 root root  4096 Feb 28 23:04 mnt
drwxrwxr-x  7 root root 4096 Feb 20 23:45 nas
drwxrw-r--  4 g0rsq  nogroup  4096 Jan 21 15:31 media
drwxrwsr-x 57 g0rsq music   4096 Feb 28 19:31 music
~$ sudo getent group music
music:x:1005:subsonic,g0rsq
total 52
"subsonic" is a user without local login, but even if I change ownership of /var/subsonic to root:root I get same issue
Also only folder I do not get "file not found" is /mnt/, but this is more restrictive than /mnt/nas, yet permissions are for same users :roll:
I just do not see where the issue with permissions is, as "subsonic" has full rwx on /music :cry:
g0rsq
Postby g0rsq » Thu Mar 01, 2018 5:48 pm
Sorry
Pretty well ignore last post as I now know the problem...but not the solution :?
The problem occurs when i do this from the install guide:-
Change user
By default the Subsonic process is run as the root user. To improve security it is strongly advised that you run it as a dedicated user with less powerful privileges. You can specify this user by setting the SUBSONIC_USER variable in /etc/default/subsonic.
I created a standard user
sudo adduser subsonic
and changed SUBSONIC_USER variable in /etc/default/subsonic from "root" to "subsonic"
After doing this I get folder not found
I understand there is a security risk using "SUBSONIC_USER=root" , but other than giving "subsonic" root privileges i do not know what to do!
When i use my own login user-name, I get the same folder not found
One possible clue might be i can not open /var/subsonic unless i am "super user" sudo -i
g0rsq@ubuntu-server:~$ dir /var/subsonic
dir: cannot open directory '/var/subsonic': Permission denied
I did try and change ownership of /var/subsonic to user "subsonic" but it made no difference :cry:
Any ideas?
g0rsq
Postby toolman » Thu Mar 01, 2018 8:55 pm
toolman
Postby g0rsq » Thu Mar 01, 2018 11:22 pm
Thanks again
I cant change "ownership" of the music folder as it is part of a SAMBA share structure, though if I re-construct all my SAMBA shares this is possible!
I did add the "subsonic" user to the "music" group, and assume as the "music" group has full access to the folders that this should enable "subsonic" to inherit these permissions on these folders.
I am going to leave things as they are for a while, while I try and understand more about users, groups and permissions.
I am new to Ubuntu and coming from Windows 10 find this all overly complicated as nothing works "out the box" :cry:
g0rsq
Postby toolman » Fri Mar 02, 2018 12:41 pm
Like I said, I don't know a thing about Ubuntu or Linux but I know that switching from Windows to Ubuntu requires some study and practice.
But on the other side: there are so much sites that offer you lessons that the switch might not be so difficult after all.
https://www.makeuseof.com/tag/ubuntu-an ... ers-guide/
toolman
