Subsonic not working
Postby flysurferrosa » Fri Mar 02, 2018 2:24 am
Problem Description: Network error occurred, subsonic unable to connect from my mobile device, when I log in via web browser, I get a big long mess of code I don't understand
Troubleshooting Steps: I tried uninstalling and reinstalling the application, which didn't seem to make a difference. restarted computer a bunch.
Playback Application and version: I use d-sub pretty much exclusively to stream from subsonic via my android device.
Subsonic Version: cannot access
Server Version: jetty-6.1.x
Hardware Platform: windows 10 10.0
Java Memory Limit: ????? not sure (Windows: found in the Subsonic Agent in the taskbar)
Problem Filename: (If you are having difficulty with a particular file, please include it's name)
Output from ffmpeg -i: (If you open a command prompt and type 'ffmpeg -i <filename>' what is the output? Ideally put this in a "code" block)
Last ten log file lines: (The last ten or so lines copied and pasted from the About screen in the Subsonic Web Interface. Ideally these will be in a CODE block as well.)
I tried my best to answer the above questions, but basically subsonic hasn't been working for a while, can't log into the web interface, it give me the following screen, and suggests pasting it here in the forum. I'm not really sure what else I need to do but please and thank you for any and all help! from web interface:
Error
Exception
org.springframework.jdbc.BadSqlGrammarException
Message
PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, final_version_notification, beta_version_notification, song_notification, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, show_artist_info, auto_hide_play_queue, view_as_list, default_album_list, queue_following_songs, show_side_bar, show_index_in_side_bar, preferred_video_bitrate from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, song_notification, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, show_artist_info, auto_hide_play_queue, view_as_list, default_album_list, queue_following_songs, show_side_bar, show_index_in_side_bar, preferred_video_bitrate from user_settings where username=?]
Java version
Oracle Corporation 1.8.0_71
Operating system
Windows 10 10.0
Server
jetty-6.1.x
Memory
Used 28 of 44 MB
Stack trace
org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select username, locale, theme_id, final_version_notification, beta_version_notification, song_notification, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, show_artist_info, auto_hide_play_queue, view_as_list, default_album_list, queue_following_songs, show_side_bar, show_index_in_side_bar, preferred_video_bitrate from user_settings where username=?]; nested exception is java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, song_notification, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, show_artist_info, auto_hide_play_queue, view_as_list, default_album_list, queue_following_songs, show_side_bar, show_index_in_side_bar, preferred_video_bitrate from user_settings where username=?]
at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:220)
at net.sourceforge.subsonic.dao.AbstractDao.queryOne(AbstractDao.java:150)
at net.sourceforge.subsonic.dao.UserDao.getUserSettings(UserDao.java:149)
at net.sourceforge.subsonic.service.SettingsService.getUserSettings(SettingsService.java:1211)
at net.sourceforge.subsonic.controller.MultiController.index(MultiController.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.invokeNamedMethod(MultiActionController.java:473)
at org.springframework.web.servlet.mvc.multiaction.MultiActionController.handleRequestInternal(MultiActionController.java:410)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
Caused by: java.sql.SQLException: Column not found: FINAL_VERSION_NOTIFICATION in statement [select username, locale, theme_id, final_version_notification, beta_version_notification, song_notification, main_track_number, main_artist, main_album, main_genre, main_year, main_bit_rate, main_duration, main_format, main_file_size, playlist_track_number, playlist_artist, playlist_album, playlist_genre, playlist_year, playlist_bit_rate, playlist_duration, playlist_format, playlist_file_size, last_fm_enabled, last_fm_username, last_fm_password, transcode_scheme, show_now_playing, selected_music_folder_id, party_mode_enabled, now_playing_allowed, avatar_scheme, system_avatar_id, changed, show_chat, show_artist_info, auto_hide_play_queue, view_as_list, default_album_list, queue_following_songs, show_side_bar, show_index_in_side_bar, preferred_video_bitrate from user_settings where username=?]
at org.hsqldb.jdbc.jdbcPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
at org.springframework.jdbc.core.JdbcTemplate$SimplePreparedStatementCreator.createPreparedStatement(JdbcTemplate.java:1322)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:585)
... 69 more
flysurferrosa
Re: Subsonic not working
Postby imral3 » Fri Mar 02, 2018 8:15 pm
I'm very interested in seeing someone answer with a clear and easy resolution to this problem as well. Seems to happen randomly. Lots of similar posts with no real resolution.
imral3
Postby jolsonpdx » Sat Mar 31, 2018 12:39 am
Getting same issue. Before and after upgrading.
Can anyone tell me how to resolve?
jolsonpdx
Postby toolman » Sat Mar 31, 2018 10:43 am
Using friend Google tells me that this means that your database is damaged, corrupt or unreachable.
You might try to stop the subsonic service and copy the content of the folder .\subsonic\db.backup to .\subsonic\db, in the proces overwriting all files in subsonic.db.
Restart the subsonic service and see if this worked.
If that doesn't solve your problem stop the subsonic service again and delete the files subsonic.data and (if still present) subsonic.lck
Restart the subsonic service.
Be aware that in deleting the subsonic.data file, you'll be losing ALL data. ( Users, mediafolders, comments, star ratings, playlists etc etc)
toolman
Users browsing this forum: No registered users and 78 guests
