503 and TLS SSLContext not available errors
Postby dookie » Wed Mar 07, 2018 3:10 pm
I am getting 503 errors after a system upgrade on a fedora 25 system. I have removed the database files and restarted everything. still no luck. In subsonic.log, I get the following:
[2018-03-07 09:50:01,178] INFO HsqlDaoHelper - Checking database schema.
[2018-03-07 09:50:01,468] INFO HsqlDaoHelper - Done checking database schema.
[2018-03-07 09:50:01,570] INFO SettingsService - Java: 1.8.0_151, OS: Linux
[2018-03-07 09:50:01,613] INFO VersionService - Resolved local Subsonic version
to: 6.1.3
[2018-03-07 09:50:01,673] WARN SettingsService - Failed to validate license.
org.apache.http.ssl.SSLInitializationException: TLS SSLContext not available
        at org.apache.http.ssl.SSLContexts.createDefault(SSLContexts.java:55)
        at org.apache.http.impl.client.HttpClientBuilder.build(HttpClientBuilder
.java:966)
        at net.sourceforge.subsonic.util.HttpUtil.client(HttpUtil.java:50)
        at net.sourceforge.subsonic.util.HttpUtil.httpRequest(HttpUtil.java:37)
        at net.sourceforge.subsonic.util.HttpUtil.httpGet(HttpUtil.java:25)
        at net.sourceforge.subsonic.util.HttpUtil.httpGet(HttpUtil.java:20)
        at net.sourceforge.subsonic.service.SettingsService.validateLicense(Sett
ingsService.java:1408)
        at net.sourceforge.subsonic.service.SettingsService.access$000(SettingsS
ervice.java:52)
        at net.sourceforge.subsonic.service.SettingsService$1.run(SettingsServic
e.java:1431)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:51
1)
ervice.java:52)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.
access$301(ScheduledThreadPoolExecutor.java:180)
run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.
java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor
.java:624)
        at java.lang.Thread.run(Thread.java:748)
Caused by: java.security.NoSuchAlgorithmException: TLS SSLContext not available
        at sun.security.jca.GetInstance.getInstance(GetInstance.java:159)
        at javax.net.ssl.SSLContext.getInstance(SSLContext.java:156)
        at org.apache.http.ssl.SSLContexts.createDefault(SSLContexts.java:51)
        ... 15 more
I have tried a few things including changing the port.
open JDK is up to date at version 8 and only one process is running for subsonic.
I have set selinux to permissive and turned the firewall off momentarily, no luck there either. The computer can access the internet for everything else.
any suggestions? I guess i could completely remove and re-install :/
dookie
Re: 503 and TLS SSLContext not available errors
Postby dookie » Wed Mar 07, 2018 6:52 pm
I just updated to fedora 26. no change. then updated to 27. no change.
I've also tried reverting to older versions. no change.
dookie
Postby G8DHE » Wed Mar 07, 2018 11:24 pm
To me the final error report suggests that the SSL licence isn't being validated! Nothing to do with Subsonic itself.
"Failed to validate license.
org.apache.http.ssl.SSLInitializationException: TLS SSLContext not available"
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Postby dookie » Thu Mar 08, 2018 12:10 am
G8DHE wrote:To me the final error report suggests that the SSL licence isn't being validated! Nothing to do with Subsonic itself.
i can buy that, but why?
I have an updated java package installed. I didn't have this problem previously...
dookie
Postby alphawave7 » Thu Mar 08, 2018 8:07 am
Many have reported better results with the Oracle implementation.
Postby dookie » Thu Mar 08, 2018 8:42 am
alphawave7 wrote:Many have reported better results with the Oracle implementation.
oracle's dominance might be changing. we just switched our java development at work to openJDK now that redhat no longer packages oracle java rpms. I'm guessing that will help drive the community.
That said, I found my problem. java-1.8.0-openjdk-headless.x86_64 needed re-installed. I had only tried reinstalling java-1.8.0-openjdk.x86_64
all seems well... :/
dookie
Postby G8DHE » Thu Mar 08, 2018 10:54 am
Probably better to ask such a question in the support group for the OS your using, it doesn't appear to have anything to do with Subsonic, so people here aren't going to be able to give you answers!
Geoff G8DHE
Version 6.0 Beta 2
G8DHE
Users browsing this forum: No registered users and 60 guests
