JUKEBOX no sound on debian (openmediavault)
Postby studiojurdan » Mon Mar 12, 2018 9:50 am
this is 48H i'm searching with no result
sorry for my terrible English (i'm french)
i' have installed subsonic as plugins in OPENMEDIAVAULT on a special debian version
i need to use first the 'jukebox" player (sound out off my server)
but i have no sound
i'm sure that the sound works in other app and alsa mixer and alsa speaker test works perfectly
can you explan where i can tell SUBSONIC to use alsa like every else?
Thanks a lot
Openmediavault 3.0.98 Erasmus,
Debian 8 (console mode only)
subsonic Version 6.1.3 (build e408c9) – October 31, 2017
Server jetty-6.1.x, java 1.7.0_151, HSQLDB, Linux (47.4 MB / 106.9 MB)
studiojurdan
Re: JUKEBOX no sound on debian (openmediavault)
Postby studiojurdan » Tue Mar 13, 2018 6:40 pm
hum, it seem that nobody know how to make the "jukebox" making regulary sound. output on the linux server.
I think tha i must find another soft tha use or can be set in audio config
studiojurdan
Postby wendigo » Sat Mar 17, 2018 4:12 pm
Not sure if that's the same case but I solved similar issue on Ubuntu by setting PulseAudio to run as service: https://rudd-o.com/linux-and-free-softw ... your-users
wendigo
Postby studiojurdan » Sat Mar 17, 2018 11:39 pm
hum, i'll try to fix with your link but i'm on debian 8, i'm not sure taht is the same than ubutu one AND
i realy don't understan how it is possible to make a subsonic as plugin in openmediavault on debian but the sou nd is not pre configured, the folder for music must be find and enter manually, the external ip don't works AND finally they ask you to subscribve to a paid version ????
studiojurdan
