Android App doesn't show files in root library folder
Postby deviltiger » Thu Mar 15, 2018 10:56 pm
Problem Description: When looking for songs in one of my top level library folders on Android I can't see files that are in that root folder. The web app shows them fine.
Troubleshooting Steps: Forcing re-scan / rebooting phone.
Playback Application and version: Latest Version from Play Store
Subsonic Version: 6.1.3 (build e408c9) – October 31, 2017
Server Version: 6.1.3 (build e408c9) – October 31, 2017
Hardware Platform: Android
Java Memory Limit: 150MB
Problem Filename: Varies.
Output from ffmpeg -i: N/A
Last ten log file lines:
[2018-03-15 03:00:51,364] INFO MediaScannerService - Scanned media library with 17500 entries.
[2018-03-15 03:00:51,937] INFO MediaScannerService - Scanned media library with 17750 entries.
[2018-03-15 03:00:52,374] INFO MediaScannerService - Scanned media library with 18000 entries.
[2018-03-15 03:00:53,012] INFO MediaScannerService - Scanned media library with 18250 entries.
[2018-03-15 03:00:53,750] INFO MediaScannerService - Scanned media library with 18500 entries.
[2018-03-15 03:00:54,537] INFO MediaScannerService - Scanned media library with 18750 entries.
[2018-03-15 03:00:55,161] INFO MediaScannerService - Scanned media library with 19000 entries.
[2018-03-15 03:00:55,608] INFO MediaScannerService - Scanned media library with 19250 entries.
[2018-03-15 03:00:55,909] INFO MediaScannerService - Scanned media library with 19377 entries.
[2018-03-15 03:00:55,909] INFO MediaScannerService - Marking non-present files.
[2018-03-15 03:00:59,069] INFO MediaScannerService - Marking non-present artists.
[2018-03-15 03:00:59,075] INFO MediaScannerService - Marking non-present albums.
[2018-03-15 03:00:59,119] INFO MediaScannerService - Completed media library scan.
[2018-03-15 03:00:59,262] INFO PlaylistService - Starting playlist import.
[2018-03-15 03:00:59,262] INFO PlaylistService - Completed playlist import.
[2018-03-15 17:39:17,816] INFO PlayerDao - Created player 12.
See attached screenshots: https://imgur.com/a/Bdhg5. Web interface has highlighted red songs. Android screenshot only has the folders (nothing to scroll to).
deviltiger
Re: Android App doesn't show files in root library folder
Postby acroyear » Fri Mar 16, 2018 12:48 pm
I think that's an oversight in the App or a bug in the API, but I'm more likely thinking the app. The API call ("getIndexes") is supposed to list songs in the root of a music folder, but it may be that the App didn't consider that a likely possibility and so had no code to handle it and render them somehow. I know my own app doesn't deal with that very well, either, because I never tested it...as again an oversight: I don't have any music files in my musicFolder roots. :?
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
