RESOLVED: Port Forwarding Problem?
Postby vbrown119 » Sun Apr 01, 2018 5:26 pm
Help!
Been using subsonic successfully for a number of years. The ancient computer it was running on gave up the ghost, so I replaced it with a refurbished Windows 10 PC. Got it set up and things were running fine when I noticed some occasional drop outs in my broadband signal. Called my provider and boosted my “promised” speed from 50 to 250. My old modem wouldn’t handle anything over 150 so I bought a new Surfboard 6190 modem. Got everything back up and running, (including Subsonic), but was still having the drop out problem, so I decided to reset the Linksys ea 3500 router to factory settings. Didn’t keep my old settings, just started over from scratch, setting up a new network, etc. Everything worked great! Super fast and no drop outs in service!
That is everything except Subsonic. It would load and open and play music either from the subsonic tray or by entering my subsonic web address on the computer it was loaded on, but I couldn’t access it from any other computer or phone. I got the following error:
This site can’t be reached
192.168.1.135 took too long to respond.
Search Google for 192 168 135 8080
ERR_CONNECTION_TIMED_OUT
Figured it was a port forwarding problem so I spent the last 2 days trying to resolve it - to no avail. When I originally installed Subsonic on the new computer, before I restored the router to factory settings, I used automatic port forwarding and it worked. I tried that first after resetting the router. When that didn’t seem to work, I set up a static IP address (using Monroe’s World - how to set up Subsonic instructions) and then when that didn’t work, using port forwarding instructions I found elsewhere on the net. No dice.
I have tried changing my port numbers. Turning off firewalls on my computers and on the router. I have turned off UPNP while trying to run a static port configuration - turned it back on. Turned NAT on & off on the router. Turned off “Filter Anonymous Internet Requests” on the router. Rebooted the computer, Subsonic and or the the router after every change. Basically tried every configuration I could think of using both UPNP and a static configuration. To no avail.
On the subsonic network settings page, when I would use UPNP, I would sometimes get a message that all was good - it was connected to my router and when using UPNP port forwarding was successfully enabled. However, even when it said it was successfully port forwarding I still couldn’t see Subsonic anywhere except on the computer on which it was installed.
So I’m stumped and humbly come here for help from those who know. Below are some screenshots that may be helpful in figuring out where this flunky went wrong. I tried to restore everything to its original configuration - the computer, router and subsonic. Firewalls are back on. I changed the TCP/IPV4 properties on the computer back to auto. Currently Subsonic says it is successfully port forwarding using UPNP but I can only see it on the server.
P.S. Today while making changes to the router settings I lost connectivity and I had to reboot it to get back online. Perhaps I should go buy a new router as well. Sigh.
License
Subsonic Premium
Version
6.1.3 (build e408c9) – October 31, 2017
Server
jetty-6.1.x, java 1.8.0_161, HSQLDB, Windows 10 (71.0 MB / 80.8 MB)
Media collection
4,395 artists
7,954 albums
74,766 songs
557.64 GB
5,195 hours
[4/1/18 9:46:12 AM PDT]INFOHsqlDaoHelperChecking database schema.[4/1/18 9:46:15 AM PDT]INFOHsqlDaoHelperDone checking database schema.[4/1/18 9:46:15 AM PDT]INFOSettingsServiceJava: 1.8.0_161, OS: Windows 10[4/1/18 9:46:15 AM PDT]INFOVersionServiceResolved local Subsonic version to: 6.1.3[4/1/18 9:46:15 AM PDT]INFOMediaScannerServiceAutomatic media library scanning scheduled to run every 1 day(s), starting at Mon Apr 02 03:00:00 PDT 2018[4/1/18 9:46:16 AM PDT]INFOUPnPServiceStarting UPnP service...[4/1/18 9:46:16 AM PDT]INFOPodcastServiceAutomatic Podcast update scheduled to run every 24 hour(s), starting at Sun Apr 01 09:51:16 PDT 2018[4/1/18 9:46:16 AM PDT]INFOUPnPServiceDisabling UPnP/DLNA media server[4/1/18 9:46:16 AM PDT]INFOUPnPServiceStarting UPnP service - Done![4/1/18 9:46:28 AM PDT]INFONetworkServiceSuccessfully forwarding port 8080.[4/1/18 9:46:32 AM PDT]INFOBootstrapVerificationFilterServlet container: jetty-6.1.x[4/1/18 9:46:34 AM PDT]INFOVersionServiceResolved latest Subsonic final version to: 6.1.3[4/1/18 9:46:34 AM PDT]INFOVersionServiceResolved latest Subsonic beta version to: 6.1.beta2
Thanks in advance for any help you can provide.
Vince
vbrown119
Re: Port Forwarding Problem?
Postby vbrown119 » Tue Apr 03, 2018 4:11 am
Resolved: The problem was a firewall. I thought I had turned off all firewalls, but it turns out that Windows 10 has a seperate network firewall that I was unaware of. Enter Settings/Network & internet/status/Firewall & Network Protection - then choose the active network - in my case private - and turn the active network firewall off. Everything works like butter now, but I will need to go back and try turning on my router and computer firewalls one at a time to see if they affect access to subsonic. I'm sure there is also a way to set subsonic as an exception so that the network firewall will let it through, but at the moment that's beyond me. I'm just glad it's working.
vbrown119
