Subsonic help in Los Angeles?
Postby Almendarez28 » Sun Apr 08, 2018 6:15 am
I was wondering if anyone in or around Los Angeles could do a house call to help me setup the port forwarding. I've racked my brain and read so many guides and still can't get the the connecttimeoutexception to go away. I thought I setup my static IP and read the portforwarding on my NGV510 router and haven't had any luck. I will compensate for it too
Almendarez28
Re: Subsonic help in Los Angeles?
Postby toolman » Sun Apr 08, 2018 10:52 am
I don't live anywhere near Los Angeles, but I found https://portforward.com/motorola/nvg510/ where there's an extensive guide on how to set up a portforwarding in your router.
Basically it's just tree steps:
1. assign your subsonic server a static IP address within the IP address range that your router is in ( default is 192.168.1.XXX ) where the router usually has the 192.168.1.254 address.
So your Subsonic server would be fine with the 192.168.1.250 address.
2. Log on to your router, go to Firewall and then to NAT / Gaming. Here you add a custom service. ( Service name : Subsonic. Global Port Range 4040 - 4040 . Base Host port 4040.
Protocol Both). Click Add to save the entry. Next assign this custom service to your Subsonic Server . Make sure all settings are saved and reboot your router just to be sure.
3. Check on your server if the connect timeout exception is gone. If you are using Windows you might add a rule to the firewall settings for Subsonic.
( http://visihow.com/Add_Windows_Firewall_Exceptions_in_Windows_10 )
toolman
Postby jgraythe4th » Mon Apr 09, 2018 2:47 am
I live in the LA area I could help you out. Send me your email and I will get in contact with you.
jgraythe4th
