folder not found windows ntfs
Postby labtopia » Sat Apr 14, 2018 3:23 am
this path cannot be set
D:\torrent\showrss\TV Shows
D:\torrent\showrss
D:\torrent\showrss\Movies
this path can be set
D:\torrent
E:\Dropbox\music
windows 10, D: is a ntfs formated microsd card, new subsonic install, premium enabled 6.1.3 (build e408c9) – October 31, 2017
Why do the D: paths not work?
pretty long time since a new build
dave
labtopia
Re: folder not found windows ntfs
Postby toolman » Sun Apr 15, 2018 12:15 pm
if Subsonic has no acces to the subfolders of D:\torrent than you can't define them in your mediafolders.
You need to check wether the account that's running the Subsonic service has acces to these folders.
If you haven't changed the account that's running the subsonic service you will find that it's the Local System account.
So you'll need to check the properties of the subfolders if the System account is granted acces.
If you have made changes to the account you'll need to verify if that account indeed has acces to the folders D:\torrent\showrss\TV Shows & D:\torrent\showrss\Movies.
toolman
Postby labtopia » Sun Apr 15, 2018 12:20 pm
i know that user EVERYONE has full control of the whole drive, i can add SYSTEM to see if it changes anything.
it will allow setting as i mentinoed
d:\torrent
but not deeper
d:\torrent\showrss
i'll post if changing effective permissions does anything positive.
dave
labtopia
Users browsing this forum: No registered users and 83 guests
