Worked fine for a while, now: Stopping Stream Null
Postby Rob Carroll » Fri May 01, 2009 4:26 pm
I've been running Subsonic for a while. Absolutely love it. However, in the last few days, I've found that on any machine other than the server, the songs will not play. you can view the albums and everything else as normal, but the song just won't start.
In the logs, I'm seeing:
INFO StreamController - Stopping stream null
To the best of my knowledge, nothing changed on the server, but once I started experiencing this, I upgraded to the latest JRE. After that didn't work, I downgraded to 6.7
I've also reinstalled the latest Subsonic release.
Any ideas?
Rob
Rob Carroll
Postby Rob Carroll » Fri May 01, 2009 4:30 pm
It's probably worth mentioning, the computer is running Windows 2000 Server, and is definitely beefy enough to handle everything it's running, including and in addition to Subsonic.
Rob Carroll
Postby Rob Carroll » Thu May 07, 2009 2:31 pm
Bump... nobody???
Rob Carroll
Postby jonathanroz » Thu May 07, 2009 3:02 pm
Do you have the same issue if you set to use an external player?
If it is Internet accessable and you want to PM me your URL and a login I will take a look to see if I can figure it out. You can always delete the login later.
jonathanroz
