HTTP ERROR 503
HTTP ERROR 503
Postby DrFloflo » Sat Apr 21, 2018 5:02 pm
Hello, this morning i have found this error :
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
I have check many site but nothing who help me. I want to keep my db, too many playlist !
Yhanks for your help !!
DrFloflo
Re: HTTP ERROR 503
Postby DrFloflo » Sat Apr 21, 2018 6:29 pm
Okayy guys i have found how to fix this error :
-Go in /var/subsonic/db and open subsonic.propreties.
-And simply add a 0 for cache_scale.
I don't know if is good but it's worked. All my playlist are here !
My file:
#HSQL Database Engine 1.8.0.5
#Sat Apr 21 20:15:37 CEST 2018
hsqldb.script_format=0
runtime.gc_interval=0
sql.enforce_strict_size=false
hsqldb.cache_size_scale=80 <=== i have add a 0
readonly=false
hsqldb.nio_data_file=true
hsqldb.cache_scale=140 <=== here too
version=1.8.0
hsqldb.default_table_type=memory
hsqldb.cache_file_scale=10 <=== and herre
hsqldb.log_size=500 <=== modify by 500 for just test ^^
modified=yes
hsqldb.cache_version=1.7.0
hsqldb.original_version=1.8.0
hsqldb.compatible_version=1.8.0
I think is the limit of database, so i multiply this capacity by 10 ^^
DrFloflo
Re: HTTP ERROR 503
Postby dave31175 » Sun Apr 22, 2018 3:20 pm
I encountered this same error last week but was leaving town for a week and didn't have time to research solutions. I'd trying restoring a backup of /var/subsonic to no avail. I returned home this morning to find your solution, and it seems to have done the trick for me!! Thanks so much for posting this!
dave31175
Re: HTTP ERROR 503
Postby microbe » Tue May 01, 2018 3:10 pm
Same error after Ubuntu update to 18.
Subsonic 6.1.3
openJDK 10.0.1
Subsonic starts with errors
/var/subsonic/subsonic_sh.log
[0.017s][info][gc] Using G1
50 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Refreshing org.springframework.context.support.ClassPathXmlApplicationContext@39ba5a14: display name [org.springframework.context.support.ClassPathXmlApplicationContext@39ba5a14]; startup date [Tue May 01 17:32:55 MSK 2018]; root of context hierarchy
89 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [applicationContext-deployer.xml]
334 [main] INFO org.springframework.context.support.ClassPathXmlApplicationContext - Bean factory for application context [org.springframework.context.support.ClassPathXmlApplicationContext@39ba5a14]: org.springframework.beans.factory.support.DefaultListableBeanFactory@fa4c865
341 [main] INFO org.springframework.beans.factory.support.DefaultListableBeanFactory - Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@fa4c865: defining beans [service,org.springframework.remoting.rmi.RmiServiceExporter#0]; root of factory hierarchy
357 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger(org.mortbay.log) via org.mortbay.log.Slf4jLog
Using WAR file: /usr/share/subsonic/subsonic.war
[0,525s][info][gc] GC(0) Pause Young (G1 Evacuation Pause) 16M->2M(126M) 2,695ms
Extracting webapp to /var/subsonic/jetty/e408c9
382 [main] INFO org.mortbay.log - jetty-6.1.x
406 [main] INFO org.mortbay.log - Extract jar:file:/usr/share/subsonic/subsonic.war!/ to /var/subsonic/jetty/e408c9/webapp
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/usr/share/subsonic/subsonic-booter-jar-with-dependencies.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/var/subsonic/jetty/e408c9/webapp/WEB-INF/lib/slf4j-log4j12-1.6.1.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
1302 [main] INFO / - Initializing Spring root WebApplicationContext
1302 [main] INFO org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
1313 [main] INFO org.springframework.web.context.support.XmlWebApplicationContext - Refreshing org.springframework.web.context.support.XmlWebApplicationContext@3da30852: display name [Root WebApplicationContext]; startup date [Tue May 01 17:32:56 MSK 2018]; root of context hierarchy
1331 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-service.xml]
1385 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-security.xml]
1408 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-cache.xml]
1419 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]
1436 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf.xml]
1448 [main] INFO org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML bean definitions from class path resource [META-INF/cxf/cxf-servlet.xml]
1465 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]; nested exception is org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:420)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:342)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:310)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
        at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
        at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
        at org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:92)
        at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:123)
        at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:422)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:352)
        at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
        at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
        at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
        at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
        at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
        at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:488)
        at java.base/java.security.AccessController.doPrivileged(Native Method)
Caused by: org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:138)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1292)
        at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1287)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:135)
        at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:92)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:507)
        at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:398)
        ... 48 more
Caused by: java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException
        at org.apache.cxf.jaxws.spring.NamespaceHandler.init(NamespaceHandler.java:34)
        at org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:129)
        ... 54 more
Caused by: java.lang.ClassNotFoundException: javax.xml.bind.JAXBException
        at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:466)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
        at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
        ... 56 more
1470 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@7ce97ee5{/,jar:file:/usr/share/subsonic/subsonic.war!/}
        ... 48 more
        ... 54 more
        ... 56 more
1471 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanDefinitionStoreException: Unexpected exception parsing XML document from ServletContext resource [/WEB-INF/applicationContext-sonos.xml]; nested exception is org.springframework.beans.FatalBeanException: Invalid NamespaceHandler class [org.apache.cxf.jaxws.spring.NamespaceHandler] for namespace [http://cxf.apache.org/jaxws]: problem with handler class file or dependent class; nested exception is java.lang.NoClassDefFoundError: javax/xml/bind/JAXBException:
1488 [main] INFO org.mortbay.log - Started SelectChannelConnector@0.0.0.0:4040
Subsonic running on: http://localhost:4040/
1510 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Looking for RMI registry at port '9412'
1591 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Could not detect RMI registry - creating new one
1669 [main] INFO org.springframework.remoting.rmi.RmiServiceExporter - Binding service 'SubsonicDeployerService' to RMI registry: RegistryImpl[UnicastServerRef [liveRef: [endpoint:[127.0.1.1:9412](local),objID:[0:0:0, 0]]]]
[1,831s][info][gc] GC(1) Pause Young (G1 Evacuation Pause) 76M->8M(126M) 7,177ms
microbe
Re: HTTP ERROR 503
Postby adenet » Thu May 03, 2018 7:29 am
Same here after upgrade Ubuntu from 17.10 to 18.04. Change Java back from 10 to 8 (openjdk) did the trick.
update-alternatives --config java
0 /usr/lib/jvm/java-10-oracle/bin/java 1091 automatischer Modus
1 /usr/lib/jvm/java-10-oracle/bin/java 1091 manueller Modus
* 2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manueller Modus
adenet
Re: HTTP ERROR 503
Postby acroyear » Thu May 03, 2018 3:00 pm
thanks for that "alternatives" - i'm making a new box on Ubuntu 17.10 and nice to know some ways around what crud I might have to deal with here. :)
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Re: HTTP ERROR 503
Postby Ratel001 » Sat May 05, 2018 12:27 am
I changed the cache configuration, and I selected my most current java version (7, requested when I was installing subsonic 6.1.3), but I still get the 503.
Ratel001
Re: HTTP ERROR 503
Postby lizard2802 » Sun May 13, 2018 6:25 pm
Hi, i've upgraded my linux ubuntu t o 18.04 yesterday
I find the same problem : error 503 Requested URI=/
I completedly reinstalled subsonic after "apt-get purge subsonic" and deletion of files in /var
I still get the problem...
When i get a look to java alternatives I get :
sudo update-alternatives --config java
Sélection   Chemin                                          Priorité  État
  0            /usr/lib/jvm/java-10-oracle/bin/java             1091      mode automatique
  1            /usr/lib/jvm/java-10-oracle/bin/java             1091      mode manuel
* 2            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      mode manuel
Any clue to help me ?
lizard2802
Re: HTTP ERROR 503
Postby dkooo » Thu May 24, 2018 1:10 pm
Hi all,
I have the same problem, I decided to switch the (not maintained ?) Subsonic to a light (Alpine) Docker environment, it's working very good!
Here the image I have used: https://github.com/marcopaganini/alpine-subsonic
Steps :
sudo apt remove subsonic
# now, add a user and group "subsonic" with uid 10000
sudo chown -R subsonic: /var/subsonic
docker pull mpaganini/alpine-subsonic
docker run \
  --name "subsonic" \
  --detach \
  --publish 4040:4040 \
  --volume "/var/music_on_host:/var/music:ro" \
  --volume "/var/subsonic:/var/subsonic" \
You need to edit this line :
dkooo
Re: HTTP ERROR 503
Postby Logicwax » Wed Jun 06, 2018 10:24 am
adenet wrote:Same here after upgrade Ubuntu from 17.10 to 18.04. Change Java back from 10 to 8 (openjdk) did the trick.
thank you so much! After searching around everywhere, this solution finally did the trick for me!
Logicwax
Re: HTTP ERROR 503
Postby dave31175 » Sun Jun 17, 2018 11:29 pm
I'm now on my 2nd time of this happening in 2 months. The first time the edits above to subsonic.properties did the trick. This time, no. I also tried copying the script file, removing the db dir, then replacing the script file, and this also didn't work.
1) Is it unreasonable to expect developer support since it's a paid app? This problem seems common enough, the person taking our money should be making an effort toward fixing the problem, no?
2) Are there any viable alternatives to subsonic? I search periodically as I hate to rely on such a flaky app, but since the demise of Audiogalaxy, I've found no other viable solution for hosting one's own music collection
3) I restored /var/subsonic from a backup, to no avail. Are there additional dirs I should also restore that might rectify the situation?
4) Barring satisfactory answers to 1, 2, and 3, how would I best complete uninstall subsonic (linux mint 17) so I can start from scratch and hope for another couple of months of use of this app I've paid for?
thanks.
dave31175
Re: HTTP ERROR 503
Postby bluesthinker » Tue Jun 19, 2018 2:33 pm
Using WIndows 10 (latest version) on PC hooked up to Sonos.
Today I got the
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/subsonic
Powered by jetty://[/color][/b]
Tried to update software, to no avail. The solutions discussed above, don't seem to fit me. Not a total novice, but not deep into coding or changing things. Do I just delete and reload or is there something I am missing. Help Help, I need this working for a weekend get together. Many thanks in advance!!!
bluesthinker
Re: HTTP ERROR 503
Postby dave31175 » Tue Jun 19, 2018 2:56 pm
bluesthinker wrote:The solutions discussed above, don't seem to fit me.
After trying the solutions above (and those mentioned in my post previous to yours) and still receiving the 503, I completely uninstalled and started from scratch yesterday. So far all is working as expected. It's certainly not an ideal solution, but apparently in this case it was the *only* solution. I do wish there was another viable means for streaming one's own music collection, but having found none, I may just have to live with starting from square one every couple of months.
dave31175
Re: HTTP ERROR 503
Postby bluesthinker » Tue Jun 19, 2018 3:39 pm
I uninstalled everything, and then reloaded the software. I get everything in the start menu, but it still gives me the
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/
Powered by jetty://
when I try to "open subsonic" from the start menu. If I could get it to open I am sure I can reset everything up. Feeling frustrated that it will not open the thing up.
Thanks in advance for any help
bluesthinker
Re: HTTP ERROR 503
Postby dave31175 » Tue Jun 19, 2018 9:50 pm
bluesthinker wrote:I uninstalled everything
Did you just do the uninstall? Or did you search for any files/folders left behind and remove them as well? Prior to uninstalling, I searched the entire hard drive for any files/folders with subsonic in the name. After I did a "completely remove" for subsonic from the package manager (I'm on Linux Mint 17 btw), I looked through to find they hadn't all been removed by the uninstallation. In my case, the /var/subsonic directory (I'm not sure what this would translate to on the windows installation) had been left behind. I manually removed that prior to reinstalling.
I don't know if this would make any difference in your case, but it's the only thing I could think of.
dave31175
