HTTP ERROR 503
Re: HTTP ERROR 503
Postby droviin » Fri Feb 22, 2019 6:11 am
So, I followed all the guides here. I even reinstalled ubuntu server 18.04 LTS. But, unfortunately, nothing seems to be working.
I'm going to try rolling back to Ubuntu 17.10
Edit: I was able to reinstall Ubuntu Server 16.04 LTS and subsonic worked. I believe that there is something with Ubuntu server 18.04 that prevents subsonic from working. Hopefully, it gets fixed in Subsonic 1.7!
Edit2: It was working fine for about a day, then it acted up again. The only new thing I installed on the server is Minecraft; I'm wondering if that's causing problems. I only have java8 installed on the system.
droviin
Re: HTTP ERROR 503
Postby guss » Fri Feb 22, 2019 7:24 pm
I'm running Ubuntu 18.04 and it's working fine with Subsonic. You have to use Java 8 with it.
guss
Re: HTTP ERROR 503
Postby droviin » Sat Feb 23, 2019 3:52 am
guss wrote:I'm running Ubuntu 18.04 and it's working fine with Subsonic. You have to use Java 8 with it.
It's another problem than just using java 8. I run into the same 503 error whether I'm using Java 8 or not.
droviin
Re: HTTP ERROR 503
Postby davekub » Mon Mar 18, 2019 12:14 am
I just got the 503 error. I've used Subsonic for several years without many issues and it was working fine a couple of weeks ago. Now, can't bring it up at all. I'm on Windows 10 Pro. I've tried several "fixes" I found online and nothing has worked yet. Has anyone heard anything at all from Sindre??
In the subsonic-service.log file I'm seeing lots of errors with bean creation:
2670 [main] WARN org.springframework.beans.factory.support.DisposableBeanAdapter - Invocation of destroy method 'shutdown' failed on bean with name 'cxf': org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'ajaxTagServiceSecure': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!)
2670 [main] ERROR org.springframework.web.context.ContextLoader - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mediaFileService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'metaDataParserFactory' while setting bean property 'metaDataParserFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'metaDataParserFactory' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot create inner bean 'net.sourceforge.subsonic.service.metadata.FFmpegParser#12b21a9' of type [net.sourceforge.subsonic.service.metadata.FFmpegParser] while setting bean property 'parsers' with key [1]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.sourceforge.subsonic.service.metadata.FFmpegParser#12b21a9' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'transcodingService' while setting bean property 'transcodingService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transcodingService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Cannot resolve reference to bean 'playerService' while setting bean property 'playerService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'playerService' defined in ServletContext resource [/WEB-INF/applicationContext-service.xml]: Invocation of init method failed; nested exception is org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error: java.io.IOException: org.hsqldb.HsqlException: Unexpected token:
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
and it goes on. The subsonic.log starts with:
[2019-03-17 19:50:27,613] INFO HsqlDaoHelper - Checking database schema.
[2019-03-17 19:50:30,602] ERROR HsqlDaoHelper - Failed to initialize database.
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.hsql.Schema25.execute(Schema25.java:21)
   at net.sourceforge.subsonic.dao.DaoHelper.init(DaoHelper.java:27)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:498)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1414)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods
... lots more of the same...
UPDATE (March 30): I finally got around to doing a full uninstall/reinstall/reconfigure and it seems to be working again. I'm assuming the database got corrupted somehow, maybe due to one of our recent weather-related power outages.
davekub
Re: HTTP ERROR 503
Postby kilgoretrout64 » Tue Mar 19, 2019 2:05 am
Oy. I just got this error today too, and I am also running Win 10 Pro. I am dead in the water. I tried the properties file edits to no avail. I tried to reinstall subsonic 6.5.1, no dice. I have similar errors reported in my subsonic.log file. I would like to avoid a from scratch install because I lose my users, my podcasts, yada yada yada. Not even sure that would work. Anyone have any ideas?
subsonic.log:
[2019-03-18 21:34:33,575] INFO HsqlDaoHelper - Checking database schema.
[2019-03-18 21:34:34,247] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: error in script file line: 1013 java.io.IOException: org.hsqldb.HsqlException: Value too long
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1375)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1335)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:132)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:64)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
   at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: error in script file line: 1013 java.io.IOException: org.hsqldb.HsqlException: Value too long
   at java.sql.DriverManager.getConnection(DriverManager.java:664)
   at java.sql.DriverManager.getConnection(DriverManager.java:208)
   ... 80 more
[2019-03-18 21:34:34,372] INFO SettingsService - Java: 1.8.0_152, OS: Windows 10
[2019-03-18 21:34:34,716] INFO VersionService - Resolved local Subsonic version to: 6.1.5
Update (two days later) - I uninstalled subsonic then did a fresh install. It's working fine now, but I had to recreate user accounts and start from scratch reconfiguring the podcatcher.
kilgoretrout64
Re: HTTP ERROR 503
Postby tfroehling@ » Sat Jul 27, 2019 8:16 am
2 all the Buster-Users also running in this error. Here is my solution.
Install AdoptOpenJDK (Tutorial: https://linuxize.com/post/install-java-on-debian-10/):
Short:
sudo apt update
sudo apt install apt-transport-https ca-certificates wget dirmngr gnupg software-properties-common
wget -qO - https://adoptopenjdk.jfrog.io/adoptopen ... key/public | sudo apt-key add -
sudo add-apt-repository --yes https://adoptopenjdk.jfrog.io/adoptopenjdk/deb/
sudo apt update
sudo apt install adoptopenjdk-8-hotspot
sudo update-alternatives --config java
Worked for me!
T.
tfroehling@
Re: HTTP ERROR 503
Postby rxpcdoc » Thu Aug 29, 2019 4:57 pm
On a new install of Debian Bullseye, I had partial success with the fix provided by tfroehling. I was able to login and configure Subsonic, but neither systemctl stop nor reload have any effect on the running process. It could be that the adoptopenjdk repository has no openjdk 8 for Bullseye; Buster is the latest.
Anyway, I hope this is resolved soon. Bullseye uses openjdk 11 as the default, and it would be nice to stay within the Debian repository system as much as possible.
rxpcdoc
Re: HTTP ERROR 503
Postby remy-porter » Mon Jan 06, 2020 1:03 pm
I'm running the Snapcraft package, version subsonic-arubislander 6.1.6+snap3, and I'm also getting the 503 error, though with a very different stack trace:
[2020-01-05 21:34:12,336] INFO HsqlDaoHelper - Checking database schema.
[2020-01-05 21:34:12,420] ERROR HsqlDaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: User not found: SA
Caused by: java.sql.SQLException: User not found: SA
        ... 74 more
[2020-01-05 21:34:12,492] INFO SettingsService - Java: 1.8.0_232, OS: Linux
[2020-01-05 21:34:12,496] INFO VersionService - Resolved local Subsonic version to: 6.1.6
[2020-01-05 21:34:12,685] WARN SettingsService - Failed to validate license.
java.net.UnknownHostException: subsonic.org: Name or service not known
        at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method)
        at java.net.InetAddress$2.lookupAllHostAddr(InetAddress.java:929)
        at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1324)
        at java.net.InetAddress.getAllByName0(InetAddress.java:1277)
        at java.net.InetAddress.getAllByName(InetAddress.java:1193)
        at java.net.InetAddress.getAllByName(InetAddress.java:1127)
        at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:45)
        at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:111)
        at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:353)
        at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:380)
        at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
        at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:184)
        at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:88)
        at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
        at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:184)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:71)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:220)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:164)
        at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:139)
        at net.sourceforge.subsonic.util.HttpUtil.httpRequest(HttpUtil.java:38)
        at net.sourceforge.subsonic.util.HttpUtil.httpGet(HttpUtil.java:25)
        at net.sourceforge.subsonic.util.HttpUtil.httpGet(HttpUtil.java:20)
        at net.sourceforge.subsonic.service.SettingsService.validateLicense(SettingsService.java:1408)
        at net.sourceforge.subsonic.service.SettingsService.access$000(SettingsService.java:52)
        at net.sourceforge.subsonic.service.SettingsService$1.run(SettingsService.java:1431)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at java.lang.Thread.run(Thread.java:748)
As you can see, it's a failure to log in to its own database. I haven't customized the database access settings in any way, and have just been running with the default.
remy-porter
Re: HTTP ERROR 503
Postby dkooo » Wed Jan 15, 2020 7:02 pm
It's time to migrate to Airsonic: https://airsonic.github.io/docs/migrate/
It's take only 5 min, enjoy open source!
dkooo
Re: HTTP ERROR 503
Postby LRanger » Fri Feb 07, 2020 11:21 am
I have check many site but nothing who help me. I want to keep my db, too many playlist !
I can only suggest trying a different java 8 version. I'm running on an arm processor, this works for me, this is the last version of java 8 running on armhf:
There is 1 choice for the alternative java (providing /usr/bin/java).
  Selection    Path                                Priority   Status
  0            /usr/lib/jvm/jdk1.8.0_211/bin/java   100       auto mode
* 1            /usr/lib/jvm/jdk1.8.0_211/bin/java   100       manual mode
Press <enter> to keep the current choice[*], or type selection number:
LRanger
Re: HTTP ERROR 503
Postby RATTY » Fri Feb 07, 2020 11:16 pm
Had subsonic for 3 years and very pleased with it on Raspberry Pi. Had an issue with ssh and the pi so had to do a fresh install (well I've done several) and I get the 503 error.
Anyone had this on a Pi and managed to fix it?
Tried going to Java 7 and it said package doesn't exist.
Clean install NOOBS software
I use to run it from Dietpi but it is no longer in the dietpi sw list ;-(
John
RATTY
Re: HTTP ERROR 503
Postby LRanger » Sat Feb 08, 2020 7:24 am
RATTY wrote:Had subsonic for 3 years and very pleased with it on Raspberry Pi. Had an issue with ssh and the pi so had to do a fresh install (well I've done several) and I get the 503 error.
John
I'm using the repository from here https://bell-sw.com/ on my Odroid, same arm7hf architecture I think.
LRanger
Re: HTTP ERROR 503
Postby RATTY » Sat Feb 08, 2020 9:37 am
Thanks for the quick reply
Unfortunately I am a complete novice on linux
I've downloaded it but unable to install it
I've also tried JAVA 7 but it states package missing obsolete or only available from another source
John
RATTY
Re: HTTP ERROR 503
Postby LRanger » Sat Feb 08, 2020 11:16 am
RATTY wrote:Thanks for the quick reply
John
I seem to have misled you on Liberica, they seem to have deleted the Java 8 armhf packages. Perhaps you can download from Oracle https://www.oracle.com/technetwork/java/javase/downloads/java-archive-javase8-2177648.html
and then follow this post I found on https://www.raspberrypi.org/forums/viewtopic.php?t=231460
Can't remember where I got this from on google, but this worked (for jdk-8u192) - change version number accordingly:
Download the JDK directly from Oracle’s website. Since Raspberry Pi is powered by ARM processor and Raspbian is a 32-bit OS, choose the Linux ARM 32 Hard Float ABI version.
When you have downloaded the right package, unpack it into /usr/java directory:
sudo mkdir /usr/java
cd /usr/java
sudo tar xf ~/jdk-8u111-linux-arm32-vfp-hflt.tar.gz
You can then create symbolic links in /usr/bin folder (so you’ll be able to use java command anywhere) by adding the following alternatives:
sudo update-alternatives --install /usr/bin/java java /usr/java/jdk1.8.0_111/bin/java 1000
sudo update-alternatives --install /usr/bin/javac javac /usr/java/jdk1.8.0_111/bin/javac 1000
At this point, you should be able to verify that your Java installation works by running the following command:
java -version.
(substituting the coorect java version, I have v211)
LRanger
Re: HTTP ERROR 503
Postby RATTY » Sat Feb 22, 2020 11:09 pm
Thank you for your help after many hours (i am a linux novice) I now have subsonic running again.
I shall resume tomorrow scanning music etc
Needs to be a bit easier for us linux illiterate types
Thanks Again
John
RATTY
