Failed to process cover art / Failed to create thumbnail
Postby BruketFans » Mon Apr 23, 2018 3:52 pm
Logg:
[2018-04-23 17:33:04 CEST] WARN CoverArtController Failed to process cover art \\MYBOOKLIVE\Public\-=MUSIK=-\Bullet\Dust To Gold [2018]\07-Wildfire.mp3: java.lang.NoClassDefFoundError: Could not initialize class sun.java2d.Disposer
[2018-04-23 17:33:04 CEST] WARN CoverArtController Failed to create thumbnail for Media file 39564 - Rogue Soldier
Feels like it could be after the latest Windows Java update (version 8, update 171).
Never had this problem before...
BruketFans
Re: Failed to process cover art / Failed to create thumbnail
Postby ils » Tue Apr 24, 2018 1:05 am
I started having the same issue recently, and it's definitely related to the most recent Java update. Uninstalling Java and downgrading back to the version packaged with the Subsonic installer fixed it for me.
ils
Postby BruketFans » Tue Apr 24, 2018 10:35 am
ils wrote:I started having the same issue recently, and it's definitely related to the most recent Java update. Uninstalling Java and downgrading back to the version packaged with the Subsonic installer fixed it for me.
Thanks for the information. I was on the right track :wink:
Hopefully there will be an Subsonic update ...
BruketFans
Postby pemholder » Tue Apr 24, 2018 10:49 am
I noticed the same today.
The question is if it is really a bug of Java or if a fix is needed for subsonic to compy with the newest java-update.
As there are always also fixes for security issues in new java-updates it cannot be a solution to downgrade permanently to older versions.
pemholder
Postby pemholder » Tue Apr 24, 2018 1:34 pm
Looking for a solution I found out that Oracle is offering already update 172 to download manually.
http://www.oracle.com/technetwork/java/ ... 33155.html
I tried this one and till now everything seems to be o.k. again.
pemholder
Postby BruketFans » Tue Apr 24, 2018 6:40 pm
pemholder wrote:Looking for a solution I found out that Oracle is offering already update 172 to download manually.
Great, it works :D
Thank you - Thank you
BruketFans
Users browsing this forum: No registered users and 70 guests
