Settings Menu has vanished
Postby lrn2swim » Fri Jun 22, 2018 6:07 pm
Clicked on the 3 bar menu icon at the top left and the settings link is totally gone. All I'm left with is Log Out, Internet Radio, Bookmarks, More, and About Subsonic. Any ideas beyond wiping everything and reinstalling?
lrn2swim
Re: Settings Menu has vanished
Postby toolman » Sat Jun 30, 2018 9:01 am
You could try to replace the existing database with the one in the subsonic\db.backup folder.
1. Stop Subsonic service.
2. Move the existing content of subsonic\db to another folder. ( just to be sure)
3. Copy the content of subsonic\db.backup to subsonic\db
4. Start Subsonic service.
5. If all's well you can safely delete the files you moved in step 2.
if this doesn't help you could try the tip from viewtopic.php?f=2&t=17878&p=75707&hilit=compact#p75707
It doesn't seem to be relevant to your problem, but it might restore the integrity of your database.
toolman
Users browsing this forum: No registered users and 77 guests
