Java Errors
Java Errors
Postby am0nrahx » Fri Jul 13, 2018 3:29 am
Problem Description: Java errors when navigating through library.
Troubleshooting Steps: Double checked java version using "update-alternatives --config java", restarted the service.
Playback Application and version: Web
Subsonic Version: 6.1.3 (build e408c9) – October 31, 2017
Server Version: jetty-6.1.x, java 1.8.0_171, HSQLDB, Linux (83.9 MB / 141.7 MB)
Hardware Platform: Ubuntu 18 VM (Running on Intel i5, 20GB RAM, 256GB SSD) 1GB RAM allocated to VM, 5GB VHDD.
Java Memory Limit: ?
Problem Filename: All
Output from ffmpeg -i:
ffmpeg version 3.4.2-2 Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7 (Ubuntu 7.3.0-16ubuntu2)
  configuration: --prefix=/usr --extra-version=2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  libavutil      55. 78.100 / 55. 78.100
  libavcodec     57.107.100 / 57.107.100
  libavformat    57. 83.100 / 57. 83.100
  libavdevice    57. 10.100 / 57. 10.100
  libavfilter     6.107.100 /  6.107.100
  libavresample   3.  7.  0 /  3.  7.  0
  libswscale      4.  8.100 /  4.  8.100
  libswresample   2.  9.100 /  2.  9.100
  libpostproc    54.  7.100 / 54.  7.100
Input #0, mp3, from '11. Blood Angel.mp3':
  Metadata:
    encoded_by      : aestv
    title           : Blood Angel
    track           : 11
    artist          : Wolf
    genre           : Metal
    album           : Ravenous
    album_artist    : Wolf
    disc            : 1/1
    composer        : Axeman/Stålvind
    date            : 2009
  Duration: 00:06:27.53, start: 0.025057, bitrate: 320 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 320 kb/s
    Metadata:
      encoder         : LAME3.98
Last ten log file lines:
[7/13/18 3:14:45 AM UTC]   INFO   HsqlDaoHelper   Checking database schema.
[7/13/18 3:14:47 AM UTC]   INFO   HsqlDaoHelper   Done checking database schema.
[7/13/18 3:14:47 AM UTC]   INFO   SettingsService   Java: 1.8.0_171, OS: Linux
[7/13/18 3:14:47 AM UTC]   INFO   PlayerDao   Deleted 1 player(s) that haven't been used after Mon May 14 03:14:47 UTC 2018
[7/13/18 3:14:47 AM UTC]   INFO   MediaScannerService   Automatic media library scanning scheduled to run every 1 day(s), starting at Sat Jul 14 03:00:00 UTC 2018
[7/13/18 3:14:47 AM UTC]   INFO   UPnPService   Starting UPnP service...
[7/13/18 3:14:47 AM UTC]   INFO   PodcastService   Automatic Podcast update scheduled to run every 24 hour(s), starting at Fri Jul 13 03:19:47 UTC 2018
[7/13/18 3:14:47 AM UTC]   INFO   UPnPService   Disabling UPnP/DLNA media server
[7/13/18 3:14:47 AM UTC]   INFO   UPnPService   Starting UPnP service - Done!
[7/13/18 3:14:57 AM UTC]   WARN   NetworkService   No UPnP router found.
[7/13/18 3:15:05 AM UTC]   INFO   BootstrapVerificationFilter   Servlet container: jetty-6.1.x
[7/13/18 3:15:07 AM UTC]   INFO   VersionService   Resolved local Subsonic version to: 6.1.3
[7/13/18 3:15:07 AM UTC]   INFO   PlayerDao   Created player 3.
[7/13/18 3:15:07 AM UTC]   INFO   VersionService   Resolved latest Subsonic final version to: 6.1.3
[7/13/18 3:15:07 AM UTC]   INFO   VersionService   Resolved latest Subsonic beta version to: 6.1.beta2
Java Errors
java.lang.ClassFormatError: Truncated class file
   at java.lang.ClassLoader.defineClass1(Native Method)
   at java.lang.ClassLoader.defineClass(ClassLoader.java:763)
   at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
   at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
   at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
   at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
   at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:133)
   at org.apache.jasper.servlet.JasperLoader.loadClass(JasperLoader.java:65)
   at org.apache.jasper.JspCompilationContext.load(JspCompilationContext.java:596)
   at org.apache.jasper.servlet.JspServletWrapper.getServlet(JspServletWrapper.java:147)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:315)
   at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:314)
   at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:264)
   at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:362)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:268)
   at org.mortbay.jetty.servlet.Dispatcher.forward(Dispatcher.java:126)
   at org.springframework.web.servlet.view.InternalResourceView.renderMergedOutputModel(InternalResourceView.java:236)
   at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:257)
   at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1183)
   at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:902)
   at net.sourceforge.subsonic.filter.ResponseHeaderFilter.doFilter(ResponseHeaderFilter.java:29)
I can navigate into the Index and go into the first two entries and actually play music but beyond that I get additional errors.
javax.servlet.ServletException: javax.servlet.jsp.JspException: Truncated class file
   at org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:854)
   at org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:791)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:742)
   at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:97)
   at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:332)
Caused by: java.lang.ClassFormatError: Truncated class file
   at org.mortbay.jetty.servlet.Dispatcher.include(Dispatcher.java:192)
   at org.apache.taglibs.standard.tag.common.core.ImportSupport.acquireString(ImportSupport.java:296)
   at org.apache.taglibs.standard.tag.common.core.ImportSupport.doEndTag(ImportSupport.java:161)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspx_meth_c_import_4(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:3980)
   at org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp._jspService(org.apache.jsp.WEB_002dINF.jsp.albumMain_jsp:628)
   ... 68 more
am0nrahx
Re: Java Errors
Postby am0nrahx » Fri Jul 13, 2018 2:03 pm
Fixed by install Java brand Java instead of Off Brand JDK.
https://www.digitalocean.com/community/ ... untu-18-04
am0nrahx
Users browsing this forum: No registered users and 76 guests
