Playback Very Choppy On Outside Networks
Postby acervo » Thu Aug 30, 2018 12:42 pm
So, I do use a VPN (PIA), but use one of their servers with an open port in order to stream music from Subsonic. I have not had any trouble for a year until recently. Every time I listen from either iSub or the Subsonic server site outside my local network, it's like the songs aren't downloading fast enough and the music will stop, wait to download some more, stop, wait to download some more, etc. What could be causing this? It's super frustrating!
acervo
Re: Playback Very Choppy On Outside Networks
Postby toolman » Fri Aug 31, 2018 10:47 pm
If you haven't changed anything on your Subsonic server, I'd say that yourISP or VPN service provider has changed some things.
Perhaps they are throttling your bandwidth?
Ever tried to bypass the VPN to check if that solves the problem?
toolman
Postby acervo » Sun Sep 02, 2018 10:16 pm
Thanks for the reply! I switched the PIA server I was on because it was definitely throttled. I was only getting 5mbps download as opposed to my normal 85-90. Crazy!
acervo
Postby toolman » Sun Sep 02, 2018 10:25 pm
So I guess that solved your problem.
Sometimes we just overlook the most obvious solution.
toolman
Users browsing this forum: No registered users and 87 guests
