Mediamonkey as front for subsonic service
Postby FlexQ » Fri Aug 31, 2018 8:03 am
Is it possible to use mediamonkey as a streamer for subsonic server ?
Best Regards,
Henrik
FlexQ
Re: Mediamonkey as front for subsonic service
Postby toolman » Fri Aug 31, 2018 10:55 pm
You could try to actrivate the DNLA feature in Subsonic:
Settings > DNLA/UPNP > Mark Enable DLNA server.
toolman
Postby FlexQ » Sat Sep 01, 2018 5:58 am
Hi toolman,
Thanks for your reply, it is quite a long time since i last played with dlna, and then it was not possible to use over the internet.
Is there a solution to that today?
/Q
FlexQ
Postby toolman » Sat Sep 01, 2018 8:05 am
If you just search the internet "DLNA over Internet" you'll find that you'll need to set up a VPN to connect to the DLNA service if you're not on the same LAN as your DNLA-server.
Subsonic does a good job at streaming your media to the internet so I just wonder what benefits you would get from using Mediamonkey as a DLNA client.
toolman
Postby FlexQ » Sat Sep 01, 2018 11:03 am
I dont, i just like the client.
But, if a VPN client is needed, I will find another solution :)
Thanks for your help
FlexQ
Users browsing this forum: No registered users and 79 guests
