Cannot use menu pane
Postby deleet » Thu Sep 06, 2018 5:09 am
When I login to my server I have the following menu image, even after rebooting.
https://pasteboard.co/HCAam19.png
The text reads as follows:
Error
Exception   org.springframework.dao.TransientDataAccessResourceException
Message   PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
Java version   Oracle Corporation 1.8.0_181
Operating system   Windows 10 10.0
Server   jetty-6.1.x
Memory   Used 34 of 157 MB
Stack trace   org.springframework.dao.TransientDataAccessResourceException: PreparedStatementCallback; SQL [select id, path, folder, type, format, title, album, artist, album_artist, disc_number, track_number, year, genre, bit_rate, variable_bit_rate, duration_seconds, file_size, width, height, cover_art_path, parent_path, play_count, last_played, comment, created, changed, last_scanned, children_last_updated, present, version from media_file where parent_path=? and present]; out of memory; nested exception is java.sql.SQLException: out of memory
   at net.sourceforge.subsonic.dao.MediaFileDao.getChildrenOf(MediaFileDao.java:68)
   at net.sourceforge.subsonic.service.MediaFileService.getChildrenOf(MediaFileService.java:187)
   at net.sourceforge.subsonic.service.MusicIndexService.createSortableArtists(MusicIndexService.java:158)
   at net.sourceforge.subsonic.service.MusicIndexService.getIndexedArtists(MusicIndexService.java:42)
   at net.sourceforge.subsonic.service.MusicIndexService.getMusicFolderContent(MusicIndexService.java:52)
   at net.sourceforge.subsonic.controller.LeftController.handleRequestInternal(LeftController.java:45)
Caused by: java.sql.SQLException: out of memory
   ... 64 more
Prior to this, I was having issues with the database scan quitting partway through, and after selecting "clean database" and scanning again it only claimed to have one file under subsonic stats. The music is still there under Index, and if I can avoid deleting my db files and having to re-tag a bunch of files that would be ideal.
deleet
Users browsing this forum: No registered users and 78 guests
